Center console plastic bezel removal | FerrariChat
Discussion in 'Boxers/TR/M' started by WDR328, Jan 14, 2007.
  1. WDR328
    WDR328 Formula 3
    Dec 11, 2003
    1,476
    The Bugscuffle Inn
    D. Rose
    Has anyone taken the plastic bezel that houses all of the electric components in the center console out. Mine has the sticky syndrome and I need to clean up some of the pieces. I have the bezel partially removed in the back but it appears to be bolted in the front where the vacuum switch is located. I would appreciate any help.
  2. uzz32soarer
    uzz32soarer F1 Rookie
    Sep 9, 2006
    3,090
    Melbourne, Australia
    Robert Hayden
    Not sure about the 512M, but on the Testa you lift it up at the rear after removing the single screw behind the console light, then when it is clear, simply slide it all towards the rear. There is a 3/8th tab at the front which on a Testa, slides under the coin holder.
