Center Console Replacement | FerrariChat
Discussion in 'Technical Q&A' started by bartman, Nov 20, 2004.
  1. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    My carbon fiber 1 piece finally arrived. Looks awesome....
  2. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    here are the pics
  3. F355Bvc
    F355Bvc Formula 3
    Dec 4, 2003
    1,733
    Lawrenceville. GA
    Vince Canipelli
    Andrew, Could you share with us the cost and supplier..
  4. PatrickShim
    PatrickShim Formula 3
    Jun 14, 2004
    1,755
    Southern California
    Patrick Shim
    It looks great! Is it for 355?
  5. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    Yes, how much?
    Having done my car (painting)...It seems you may have a problem. The stock one is 3 pieces that allows you room to plug/unplug your rocker switches. To remove the old see the center consol bubbling thread, there's step by step instruction. Takes less than 10 minutes to remove.
    To install, you will need to begin at the top rocker switches and start moving down. Boy, that will have to be a precise fit!
    All you need is a screwdriver except when you do the A/C controls, to remove the knobs you will need a tiny snap ring remover tool...if you don't have one just take the unit to a local gas station and ask them to unsnap the rings...most guys won't mind.
  6. FL 355
    FL 355 Formula 3
    Nov 3, 2002
    1,665
    Ft Laud
    Frank Lipinski
    PS does the ash tray have hinges on your new piece or what?
  7. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    Yes it is for a 355. It's 1 piece that will fit into the 3 pieces perfectly. The supplier was Valence USA. Click sponsors and you'll get their info. Mine was the first 1 piece they made, so it's not on their web site yet.
  8. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    Yes it has hinges, the ash try is the same as the 3rd piece. it opens so you can get to the cig lighter
  9. delaney
    delaney Formula Junior
    Nov 8, 2003
    721
    Montgomery TX
    PETER DELANEY
    This does look like the ultimate fix ...
    Again ..
    a) How much did it cost?
    b) Do you still get the GREEN illumination through the decals .. looks like there's no color in the photos.
    Regards,
    Pete
  10. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
    Call Brian or Chris. They will give you the cost. My cost might have been different since they designed it for me and it was the first one. It will not illuminate, but it is bright enought that you will be able to see the writing with the dashboard lights. My car is in for 15K service and they are installing it for me (althought Brian/Chis said it's an easy do it yourself install). When I get the car back in a week or so, I will take pics of it installed.
  11. bartman
    bartman Karting
    May 17, 2004
    127
    new jersey
    Andrew
