Center wheel cap secure installation | FerrariChat
Discussion in '308/328' started by Irishman, Jan 31, 2014.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    So I got four new center wheel caps and now have already lost one within a few months. Three seemed quite snug. One seemed loose so I put some gorilla glue on it at installation. The gorilla glue cap has not come off. I lost one of the ones that originally seemed snug at installation.
    I have ordered a replacement cap. Besides gorilla glue any advice for ensuring I don't lose this cap again?
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Are you sure it wasn't stolen?
  3. George Vosburgh
    George Vosburgh F1 Rookie
  4. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    There shouldn't really be much outward force on them. That said, as I reported in another thread, the fit on aftermarket wheels tends to be anywhere between acceptable to terrible. They should fit utterly perfect on original wheels though. I wouldn't trust glue more than simple gravity and friction... if they aren't fitting they aren't fitting. My 2 cents.
  5. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    Man, when I saw Gorilla Glue I cringed. It'll hold I suppose, but it very well might pull paint of the wheel if ever removed. Hope not, but before you go to remove it, if ever, I'd prophylactically apply something to weaken the glue before carefully removing the cap.
  6. FiatRN
    FiatRN Formula Junior
    Nov 21, 2008
    319
    Denver, CO
    Jonathan Drout
    #6 FiatRN, Feb 1, 2014
    Kevin
    You can wrap a turn of bicycle handlebar cork tape around the "fingers" of the centercap, then carefully insert it for a tight fit. Alternately, you could use a couple of turns of electric tape. Don't pull it too tight, or use too much, so as to only make the part fit snugly - avoid bending or cracking the fingers.
    This assumes a cap such as these from Ricambi.
    Jonathan
    the FiatRN
    Denver, CO
  7. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Wow, stolen is a possibility I just hadn't considered. And, yeah, the gorilla glue was a bit heavy handed but since the original caps had been on for 35 years I was taking a long term outlook with these new ones :). I had just painted the wheels myself which is why I got the new caps. Thanks, Jonathan for the suggestion of tape.
