CFC201F (197533) and ThinkDiag+ | FerrariChat
Discussion in '360/430' started by cwingert, Jul 13, 2023.
  1. cwingert
    cwingert Karting
    Jun 8, 2011
    59
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,784
    Central NJ
    Dominick
    Try the others in the list
    3.01
    First and second generation
    When you get something between 14 and 22 you have a good match
    What year is that TCU flashed to ?
  3. cwingert
    cwingert Karting
    Jun 8, 2011
    59
    #3 cwingert, Jul 13, 2023
    I tried all 3 gearbox ECUs in the ThinkDiag software. The first "seemed to work" except for the data.
    The TCU is stock with the software came from the factory.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,784
    Central NJ
    Dominick
    do you have the unit of measure set to metric ?
  5. DanNE
    DanNE Formula Junior
    Jun 7, 2013
    655
    I just got a ThinkDiag 2 today and I can't connect to any of the TCUs (tried all 4 options). Car is a 2003 model so it should be the second generation. Ferrari database is 11.10.
  6. cwingert
    cwingert Karting
    Jun 8, 2011
    59
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,784
    Central NJ
    Dominick
    ok .. when you are in NJ I will call you in on that :)
    cwingert likes this.
  8. ForzaYYZ
    ForzaYYZ Karting
    Sep 4, 2016
    67
    Toronto, Canada
    Sebastian
    Was thinking of getting this. How can I tell if I have an updated TCU? Also, does the Thinkdiag2 read PIS and Clutchwear on Factory ECUs for 2001 360F1?
  9. cwingert
    cwingert Karting
    Jun 8, 2011
    59
    Pull the panel that covers the TCU behind the passenger seat (for LHD).
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,784
    Central NJ
    Dominick
    Unfortunately not
  11. ForzaYYZ
    ForzaYYZ Karting
    Sep 4, 2016
    67
    Toronto, Canada
    Sebastian
    Thanks, but what how will I know when I look at it?
  12. cwingert
    cwingert Karting
    Jun 8, 2011
    59
    See above in the thread, I took a picture of mine. It has a Ferrari Part Number and Model Number on it.
  13. ForzaYYZ
    ForzaYYZ Karting
    Sep 4, 2016
    67
    Toronto, Canada
    Sebastian
    It’s a CFC201F.05. (211023).
    Is this a CS TCU or no?
    And can I only check PIS and Clutch life - or can I set PIS too with this version?
    How can I tell if it’s been flashed updated?
    So many novice questions - LOL
  14. grtoz
    grtoz Karting
    Dec 14, 2010
    161
    Byron Bay, Australia
    Graeme Towers
    #14 grtoz, Jul 15, 2023
    You have the last and most recent version of the TCU for the 360. This TCU, 211023, gives quicker shifts than the earlier versions as it incorporates the lessons Ferrari learned from the mapping of the Challenge Stradale TCU. With the ThinkDiag you can read the clutch parameters and set the PIS.
    Sent from my SM-G955F using FerrariChat.com mobile app
