chalenge brakes? | FerrariChat
chalenge brakes?
Discussion in 'Technical Q&A' started by ferraridriver, Nov 17, 2003.
  1. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    What, exactly, is the difference between 355 challenge brakes and regular 355 brakes?
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,654
    Inexactly:
    The calipers are bigger
    The rotors are larger
  3. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    From this thread under Philippe's post:
    Even though they're on a 348, this is a photo of the 355 Challenge set-up complete with screw-in lug studs and aluminum nuts to replace the lug bolts.
    HTH,
    Rob Schermerhorn
  4. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    FWIW, Dave, if you're thinking about upgrading your braking system, be advised that stock 355 wheels will NOT clear the Challenge brake setup.
    vty,
    --Dennis
  5. Philippe
    Philippe Karting
    Nov 2, 2003
    68
    Brussels, Belgium
    Dennis, I am almost 100% sure that the Challenge brake set up can accomodate 355 stock wheels (surely not 348 stock wheels). My 348 is equipped with the full 355 Challenge brake set up and 355 Challenge Speedline wheels. I have somewhere a set of 355 stock wheels and will make the check. I will let you know. Philippe
  6. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I've already checked. Stock 355 wheels definitely don't clear the CH brakes (not on a 355 anyway)
  7. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    No, they don't fit Challenge brakes, spoke hit calipers.
  8. ferraridriver
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    So its the spokes that interfere, not the internal diameter of the wheel?
    Second question, is there an aftermarket 18" wheel that will clear or must one go to 19" wheels?
  9. Philippe
    Philippe Karting
    Nov 2, 2003
    68
    Brussels, Belgium
    Confirmed! 355 stock wheels does not accomodate challenge brakes without spacers. By the way if someone is interested in my set of 355 stock wheels, send me an e-mail. Philippe.
  10. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    Challenge Speedline wheel clears (it's 18"). This is the Challenge package, no need for 19's.
