Challenge Stradale TCU Upgrade | Page 6 | FerrariChat
Discussion in '360/430' started by Markjayw, Feb 15, 2011.
Thread Status:
Not open for further replies.
  1. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Question for you Eddie,
    If you alter or change to much the pis value, can it affect the idle?
  2. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    If its set too low the input shaft can see RPM when the cars at idle, in gear, foot on brake. The clutch drags which can pull the idle down, though if it's this severe you usually have issues getting reverse when the car is hot....
  3. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    You might solve one of my problems!
    I need to put back the sd3
  4. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
  5. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Yeah, but what she didn't tell ya' was she had been doing rolling burn-outs too! :p
  6. 360Jet
    360Jet Rookie
    Jan 18, 2013
    3
    So, it sounds like it is hard to beat the UK CS TCU deal which will allow PIS settings, and the other benefits mentioned in this thread re the CS TCU, except maybe Eric355's option?!
  7. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    I'd be most disappointed if she hadn't done a few burn outs - she is pretty accomplished on the track as a driver.
    Besides - going in reverse is highly over rated.
  8. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    :) :p Agreed!
  9. DannyP
    DannyP Rookie
    Apr 8, 2012
    9
    Amsterdam
    Danny
    I got one from Eric with the reflash. It works great, absolutely worth the money, thanks again Eric!
    I already had the '02 tcu, but this is way better :)
  10. tazandjan
    39,363
    Eric has been buying compatible TCUs, and his reflashed TCUs can be installed with no SD2 required, at least initially.
  11. eric355
    eric355 Formula 3
    BANNED Silver Subscribed
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    Sorry Danny, I missed your post. Thanks, It was a pleasure to do it for you.
    Hope you are still happy with it :)
  12. eric355
    eric355 Formula 3
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    Yes, Terry, you are correct, they have worked OK on all the cars without the need of a SD2/3. Though, a fine tuning to match exactly the characteristics of each can be a plus.
    The range of compatible TCUs has extended, CFC201F.05 (360 TCUs, but the very earliest ones) and CFC201F.50 (Maserati TCUs) can do the job.
  13. DrDon
    DrDon F1 Rookie
    3,627
    Infractionville
    Armando Decredenza
    Eddie, does that mean it does a better job of throttle matching on shifts? That would be what I am looking for? Formula Dynamics does claim less clutch wear on their website with the upgrade.
    IMO, the cost of the Formula Dynamics upgrade is more than a used CS TCU, so not sure what the real advantage is other than a simpler install. I assume it sits on the buss and interjects.
  14. 360michael
    360michael Rookie
    Feb 21, 2013
    10
    Melbourne, Australia
    I've recently switched over to the CS TCU in my 2001 360 which has been a great improvement, however, I now have to have the ignition key turned and held for about 3 or 4 seconds for the starter to engage and the engine to start. It starts completely normally, just that the key needs to be turned for a few seconds before anything happens. For those of you that have changed over, do you have the same thing happen?
    My ferrari mechanic told me its because the the CS has the starter button which needs to be held down for a number of seconds, and this signal runs through the TCU. Interested to hear others experience with this...
  15. RedTaxi
    RedTaxi F1 Rookie
    3,365
    New Zealand
    Glen
    I changed to the CS TCU and no difference in starting.
  16. freaky1
    freaky1 Formula Junior
    Dec 10, 2012
    434
    Sydney, Australia
    Paul
    I have an 01 360 with the stradale TCU and like yourself, I need to hold the key for 3-4 seconds cranking before it starts. Its the same whether the car is cold or warm. And even straight after unplugging the battery tender.
    It starts just fine everytime, so I take this to be normal behaviour.
    I cant actually recall if it started quicker with the orginal TCU (the very first revision fitted ) as the upgrade was one of the first things i did after i purchased the car.
  17. THL
    THL Karting
    Jun 11, 2009
    158
    Denmark
    Thomas Harvej Larsen
    Hi Eric
    PM sent
    Regards Thomas
  18. 360michael
    360michael Rookie
    Feb 21, 2013
    10
    Thanks for the response guys.
    Knowing it's potentially happening with at least one other is a slight relief. Anyone have any ideas as to why the CS TCU may do this? Anyone with a stradale able to chime in and give an estimate of how long you need to hold the start button down to fire up - if indeed this is a CS TCU issue?
  19. DannyP
    DannyP Rookie
    Apr 8, 2012
    9
    Amsterdam
    Danny
    I also have this, but doesn`t bother me.
  20. mark.sch
    mark.sch Rookie
    Jun 5, 2013
    3
    Germany
    Hello,
    is there any possible upgrade path for the old CFC201F.01 176552 TCU. Have equipment here to read/write 29F200 and 95080 on bench.
    Best wishes,
    Mark
  21. spiderscott
    spiderscott Formula 3
    1,662
    Ratarossa HQ UK
    Ratarossa
    Yes i have this also ...its more like 6 or 7 seconds on mine before the car will be ready to fire up, I have had 2 different factory stradale TCUs in the car and both have been exactly the same.
  22. mikegr
    mikegr Formula Junior
    Jul 3, 2012
    415
    Europe
  23. mark.sch
    mark.sch Rookie
    Jun 5, 2013
    3
    Germany
  24. mark.sch
    mark.sch Rookie
    Jun 5, 2013
    3
    Germany
    Biggest prob seems to get the necessary binaries (e.g. CS one) to program the ecu - at least I have not found any shared info so far.
    From the hardware side, the 360 challenge TCU seems to be great for older TCUs (CFC201 hardware). Anyone with experiences porting those maps to the very early 99-01 TCUs?
  25. targa81
    targa81 Karting
    Sep 28, 2009
    116
    I'm looking forward to upgrading my 176552 to a CS TCU , I plan on installing it myself and will set up with the SD soon after. Can the mileage discrepancy be corrected at a later date or does this need to be done in initial install? Anything else that an SD is urgently needed for other than setting PIS? I'm sure my clutch thickness readings have already been altered so dont care about transferring the old clutch wear numbers.
