change battery 348 spider | FerrariChat
Discussion in '348/355' started by rusty2010, Oct 22, 2016.
  1. rusty2010
    rusty2010 Formula Junior
    Sep 29, 2009
    476
    avon in.
    rusty
    I cannot figure out how to jack up the car to get to the battery, I don't know where the jack is,,please help me!
  2. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Most 348s did not come with a jack (there may have been some 348s with a factory spare option but AFAIK they weren't sold in the US) and you wouldn't really want to trust that jack anyway. Use a floor jack or a lift. The jacking points are shown in at least one thread here and I think they're in the manual as well. You don't need to raise the car far enough to accommodate a standard jack stand so use some lumber for backup in case the jack fails.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #3 2NA, Oct 22, 2016
  4. rusty2010
    Sep 29, 2009
    476
    avon in.
    rusty
    Thanks I spent an hour or more searching the car and manual for the jack.
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,323
    Palos Verdes
    Vince V
    LOL, that's pretty funny. When I bought my 348 Spider, I got a primer for the car from the seller, so I never had to learn this lesson. Looking at the repair kit in the trunk, you'd see the mobility kit of the package, which is a bottle of goop that is supposed to provide a patch and reinflation in a pinch. Laughable.
    Regarding the battery, you need a floor jack placed under the left front jacking point. It's looks like a double wall steel edge. Loosen lug bolts first then jack up the car to remove the front wheel. Turn the wheels to the right to give you more access. Remove the panel in front of the wheel, in the wheel well, below the headlight. It's a bit finicky to remove and be careful with the fiberglass panel below the battery because it can break. This is a good time to inspect and repair the battery mounting clamps if they look rusted/eroded.
    Fvo likes this.
