Change oil | FerrariChat
Change oil
Discussion in '612/599' started by giacomo b, Jan 27, 2023.
  1. giacomo b
    giacomo b Rookie
    Jan 23, 2023
    44
    ITALY
    giacomo BRINDANI
    Hello, can anyone tell me the procedure oil change for the 599...what RPM should it be driven to and for how long?
  2. Skidkid
    Skidkid F1 Veteran
    9,520
    Campbell, CA
    John Zornes
    #2 Skidkid, Jan 27, 2023
    Are you asking change (remove & replace) or check the oil level?
    Procedure to check the oil level in a 599 is noted here. The last post in the thread also contains the info and may be more clear.
    https://www.ferrarichat.com/forum/posts/148108406/
  3. giacomo b
    giacomo b Rookie
    Jan 23, 2023
    44
    ITALY
    giacomo BRINDANI
    My question was procedure to Check the oil level..... i have seen the link ...Thank yuo very much !!
    Skidkid likes this.
  4. Skidkid
    Skidkid F1 Veteran
    9,520
    Campbell, CA
    John Zornes
    Glad to help. It is fiddly and if you get it wrong, you ruin the MAFs.
  5. George Vosburgh
    George Vosburgh F1 Rookie
    Do Not Over Fill!
    Anthony James and Skidkid like this.
  6. giacomo b
    giacomo b Rookie
    Jan 23, 2023
    44
    ITALY
    giacomo BRINDANI
    thanks for your valuable suggestions!!
