Change rear turn signal bulb? | FerrariChat
Discussion in '360/430' started by Roadking80134, Mar 11, 2015.
  1. Roadking80134
    Roadking80134 Formula Junior
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    #1 Roadking80134, Mar 11, 2015
    Good morning! I need to change my driver's side rear turn signal bulb. I've opened the panel and it seems the housing is somewhat difficult to get at. I'm guessing.. remove the plug in lead, unscrew the two knurled bolts.. and then??
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    I know real men don't but did you try looking at the owners's manual ?
  3. Roadking80134
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    I was kinda looking for a process... see if I was missing something. Getting access to the area is a bit.. awkward.
  4. vrsurgeon
    vrsurgeon F1 World Champ
    16,521
    Charleston, SC
    Curt
  5. Speedster_4_me
    Speedster_4_me Karting
    Dec 10, 2013
    161
    SF Bay Area
    Jonathan
    Did this couple of months ago - have to remove the entire light pod to get the bulb/plate out. 2x10mm nuts (top and bottom) directly on top and bottom of the thumb screw that remove the plate.
  6. viperboy
    viperboy Rookie
    May 27, 2013
    48
    South Carolina
    Joe
    Had to do this exact same thing a month ago. You are in the right direction. And yes, it is very tight in there, you just have to wiggle and maneuver. First, unscrew the top and bottom "chrome looking" nuts there in the picture. Then, wiggle like I sad and the compartment will come off. twist bulbs out and then twist new ones back in. You're done! Let me know if you have any more questions about this.
  7. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,731
    Just East of Weird
    Bob
    Just be careful when unscrewing the knurled knobs so that they don't fall into never-never land below.
    Sent from my iPad using Tapatalk HD
  8. Roadking80134
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    Thanks guys! I'll work on it today. Good to hear from people who done the same thing. Not a lot of space to wiggle stuff loose!
  9. rongotti
    rongotti Karting
    Apr 11, 2015
    244
    North Florida
    My bulbs won't budge, I am worried it's going to break and cut my fingers. Do they just unscrew? Quarter turn or threaded?
    Sent from my SM-N910V using Tapatalk
  10. rob4092xx
    rob4092xx Formula Junior
    Mar 8, 2010
    570
    Phoenix, AZ
    Look at the replacement bulb to tell. Put duct tape all over the glass part of the bulb and try it again. 2-3 layers of tape. The tape will keep it from breaking the glass. Even if you do break the glass or base, the base that is stuck in the plug is simple to remove with needle nose pliers.
  11. mello
    mello F1 Veteran
    5,485
    CA Bay Area
    Steve
    Did you push in the bulb slightly before turning?
  12. rongotti
    rongotti Karting
    Apr 11, 2015
    244
    North Florida
    I did not, I will attempt this again
  13. rongotti
    rongotti Karting
    Apr 11, 2015
    244
    North Florida
    Perfect, worked like a champ! Thanks guys!
  14. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    What a ^&^%@! project to change a bulb!!!!
    YIKES!!!!!
  15. mello
    mello F1 Veteran
    5,485
    CA Bay Area
    Steve
    You can't expect anything less from a Ferrari! LOL!
  16. cgfen
    cgfen Formula Junior
    Jun 1, 2015
    447
    vista ca
    i recommend that you place a towel or rag below the light pod to catch things that you drop
    LOL
    Funny how what you / i know doesn't hold true for all depending on their experiences.
    I doubt that I would have told a person to push and turn if i were writing instructions.
  17. Wisky
    Wisky Formula Junior
    Nov 13, 2006
    273
    Ridgewood NJ
    David
    Just loosen the 3 nuts that hold the tail light in (careful, dont let them fall)...
    Remove the whole tail light assembly.
    Replace the bulb.
    Reattach the wiring harness.
    Tighten the 3 nuts.
    Reattach the engine bay panel.
  18. mello
    mello F1 Veteran
    5,485
    CA Bay Area
    Steve
    You need to add the most important step: "Push in the bulb slightly before turning". LOL!
