Changes in smog equipment over 3X8 history | FerrariChat
Discussion in '308/328' started by American Pie, Jun 11, 2008.
  1. American Pie
    American Pie Karting
    Nov 3, 2007
    83
    Camarillo, CA
    Larry
    Can anyone tell me what changes were made to the factory smog equipment on 308s and 328s over its history? For example, what was the first year for cats? Was the smog pump done away with at some point during production. and if so, during which model year? And did the QV have less intrusive smog controls and run significantly stronger?
    Yes, I'm in Kalifornia. But I hate the idea of smog equipment strangling a highly tuned motor that wants to be unleashed, and I'm looking for the best compromise.
  2. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    While I cannot give you the whole story, one part is that is the late qv/3.2 they went to a single cat from the QV's previous dual cat in the US/Ch cars to add a single pre-cat O2 sensor enabling lambda feedback on the US/CH K-Jetronic by means of a frequency valve modifying the control pressure. The Euro market qv/3.2 soldiered on with the original non-lambda system.
    The QV/3.2 US cars also did not have a pump but rather air injection at the head exhaust port driven by exhaust pulsing and enabled by check valves.
    Some one else may add or correct me,but this is what I remember.
  3. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #3 eulk328, Jun 11, 2008
    The CH (Swiss Market) 328's do not have a frequency valve (and of course no O2 sensor because of that). They do have the thermocouple and associated circuitry to activate the "slow down" light in the event of cat. overheating.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Thanks for the correction. Those dang CH cars always confuse me as they are always somewhere not really Euro and not US.
    I think also the smog pump may have just been on the 2v cars.
  5. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I think they were designed just to add confusion and "mystery" :)
  6. Dr Tommy Cosgrove
    36,451
    Birmingham, AL
    Tommy
    The twin cats stopped with 83 models. 84 and on were single cats
  7. bill brooks
    bill brooks F1 Veteran
    6,050
    waynesburg,pa
    bill brooks
    what about the air injection?
    will engine performance degrade if it is disconnected or non-functional?
  8. thecarreaper
    thecarreaper F1 World Champ
    18,076
    Savannah
    no.
    some states do not require older cars to meet emissions anymore. many here do not have the equipment installed at all.
  9. Dr Tommy Cosgrove
    36,451
    Birmingham, AL
    Tommy
    As soon as you can get away with it (depending on the state) just yank it off and get rid of it.
  10. bill brooks
    6,050
    waynesburg,pa
    bill brooks
    is that a yes or a no with regard to engine performance degradation?
    if big brother is reading this forum,we are voting for the wrong folks!
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    The early cars made do with air injection into the exhaust stream only upon deceleration and NON CAT legal thru 1977..a thermoreactor muffler was often upgraded to a normal ANSA.
    After that it gets a little more complicated, so that's why the glass and NON CAT cars are trending upward in value, IMO...
    Now that the air injectors and plumbing are aging they can damage your engine, so my systems are stored "off the car" for safekeeping...:)
  12. bill brooks
    6,050
    waynesburg,pa
    bill brooks
    "how much do you guys charge for not playing...."
    groucho marx
  13. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    For the USA:
    The 76-77 cars had a heavy thermoreactor muffler (kinda like a primitive cat and muffler in one) with air pumps.
    The 78-79 cars were carbed and switched to a pair of cats, plus a muffler, and air pumps.
    The 80-82 two valve injected cars had the same setup except with Bosch fuel injection.
    Once it gets to the QV in '83, it gets a little more complicated and I'm not that knowledgeable. 83 was an odd year for some models and then everything changed in 84.
    Most people at this point have removed the air pumps in states where emissions testing is not required for these cars, and then plugged the exhaust manifolds. It should actually improve the performance of the car and reduce the header temps.
    Birdman
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #14 snj5, Jun 12, 2008
    "You can't afford it"
    Chico Marx
    The air injection "in theory" should not affect performance so much. However, in the early models with air injection the injection nozzel was this perforated tube that actually hung down in the flow stream. While a hinderence to flow, these also deteriorate with time into a mess hanging down into the exhaust flow. Later cars, probably starting with he qv and certainly by the 3.2, did away with these terrible injectors with an new design injector that did not extend past the wall of the port. there are several old FChat threads on replacements and very nice block offs for these early injectors.
    The pumps do rob some hp off the camshaft, but a larger problem is just disconnecting the drive withour removing the pump. I am told that if the air pump is left off the drive yet still hooked up to the system they will seize, and then cause damage if re-hooked up (say for an inspection).
    Cats are a somewhat involved story, as cat technology changed as the cars developed. Very briefly, the early cats are quite high resistance, and prone to failure with even more resistance. Later and newer tech cats, such as the 328, were more efficient and had less flow restiction. In the US cars, the single O2 lambda necessitated the single cat system, which does negate some of the exhaust pulsing efficiencies of the flat crank (note that the Euro system stayed separate).
