Changing a twin to single plate clutch | FerrariChat
Discussion in '348/355' started by mad dog, Jan 27, 2014.
  1. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Has anyone done this?
    I've seen the odd mention but not a confirmation.
    Obviously you need to change the starter ring, clutch itself and flywheel.
    My main question is are the voith systems the same? and can you just swap the flywheel over? Not sure they can be as there needs to be enough room to accommodate a twin and keep the same placing for the starter ring and throw-out bearing.
  2. MRF40@yahoo.com
    [email protected] Formula Junior
    Jan 1, 2006
    563
    Planet Urf.
    like whut? Ralph??
    1) sell the 348
    2) buy a 355
    3) be happy ever after
  3. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    He already has a 355, but misses his 348
  4. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    You must change the face plate on the flywheel, t/o brng the same.
    There is no good reason to go to this expense unless you already have the parts.
  5. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    We are machining some new flywheels from a chrome moly billet. I was mainly doing this for a Gallardo and also the 355 as they are so prone to warping and you can only grind so much off. Whilst at it I thought we could do the 348 flywheels as well, as they are so very expensive to buy complete with the voith system. and whilst at it this question occurred and could be another option for people. I had always thought of doing it when i did have a 348 but never got around to the detail.
  6. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Very well!
    Proceed. :)
  7. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
    merci kind sir
