Changing bulbs in 355 third brake light | FerrariChat
Discussion in 'Technical Q&A' started by f355spider, Dec 17, 2004.
  1. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,047
    Looks like I need to drill out the rivets on that black trim piece before removing the four screws on top....yes?
    I have a single bulb out in the middle of the array....I bought 7 replacements and will change them all. I don't think I want to do this again in four months...
    Any advice would be appreciated.
  2. RF128706
    RF128706 Formula Junior
    Apr 8, 2004
    280
    Dave, sorry, no advice, but it would be great if you could post some pics of the job. I've looked in the parts fiche and it does not show rivets. I've attached the pic which may help. What does the owners handbook say ? Bulb changing should be in there ? Item 26 is listed as a screw.
  3. LetsJet
    LetsJet F1 Veteran Owner
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    If the black grill has to be removed then yes your going to have to drill the rivets, IMO. I would have thought you could change a bulb w/o having to do that though. Good luck and let us know if you can remove the screw from behind.
  4. f355spider
    May 29, 2001
    18,047
    Third brake light info is omitted in the owner's manual, go figure. There does not appear to be any way to access from the front (engine compartment). If I go from the rear, the first thing that must come off is a black metal trim piece along the top...it is secured with a rivet at each end. Then there are four screws from the top, looks like the entire perforated metal plate and brake light would come out the back....
  5. RF128706
    Apr 8, 2004
    280
    Sounds typical F. to me. I just ran down and looked in my WSM for you but it's not in there either, least not in my copy.
    Let us know how you get on.
    RF.
  6. LetsJet
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    I just looked in the PDF parts and service manuals............ not much help.
    Except, it clearly is a nut that holds the brake light in place. So, if you could reach it from behind you might not have to pop the rivets.
  7. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Interesting question, Dave. Just out of curiosity, I went out in the garage to see how the third brake light works on the 348. The assembly comes out easily with just two screws, but it seems that Ferrari and Hella are not interested in having the bulbs replaced - it looks like the assembly is not intended to be opened for access to the bulbs. It does indeed have seven bulbs, and the housing is marked 12v 1,5cp. There is no information in the Owners Handbook on replacing these bulbs, and they are not included in the chart of replacement lamps.
    You say you have seven new bulbs - how did you determine what bulbs to purchase, if you have not yet disassembled the housing? Did someone (FoS?) have a listing? The diagram shown above apparently does not show replacement bulbs?
    Do they expect you to buy an entire new third brake light assembly if the bulbs go bad?
  8. f355spider
    May 29, 2001
    18,047
    I guessed on the bulbs, based on specs and looking at the ones from a 348 (sylvania #2723). The housings look the same for the 348 and 355. I still have not gotten into mine, and may hold off. I was "told" the center bulb was out, but now find that it is only dim, not burned out....so I might wait it out; at least until it gets worse.
  9. 1badboy
    1badboy Formula Junior
    Dec 11, 2004
    290
    Hermosa Beach, CA
    Eric Rayl
    DaveHanda, did you ever figure out how to replace just one bulb in the 355 center brake light, and if so, what was type you used?
    It's frstrating that manual totally ignores this issue...
    Any info you have will be appreciated.
    Eric
  10. f355spider
    May 29, 2001
    18,047
    Yes, I performed the job, and indeed the rivets on each end of the black metal trim peice must be drilled out. Then remove the screws on top...and you can access the Hella third brake light housing. Once removed, the housing can be seperated into two pieces. The bulbs are as I listed in the above post..I went ahead and changed them all out. Reassembled in reverse, installed new rivets, and painted them gloss black with a little Testor's modeling paint from the local hardware store.
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    I would humbly suggest replacing the ancient bulbs in the third brake light with modern LEDs that will never burn out (why do this job again?!). One potential LED source that I've used for my side marker lights is here: http://www.eautoworks.com/
  12. f355spider
    May 29, 2001
    18,047
    I don't see a replacement LED for the #2723 bulb..and the process to replace them is not all that difficult...probably took less than one hours time. And the bulbs were about $1.50 each. Replace them all, and you are good for another 7 or 8 years....
    Cole_ve likes this.
  13. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    So the 3rd brake "light" doesn't use the 1156 brake bulbs like the rest of our brake lights?
    Interesting.
    Anyway, I was under the impression that the Sylvania 2723 was our twist-fit dash light part number. If so, then this LED should replace it I'd guess: http://www.aceparts.co.uk/product_info.php/cPath/52/products_id/96
    Oh, if the lights need to be push fit instead of twist fit (dash board, gauges, or 3rd brake light), then this LED might work: http://www.aceparts.co.uk/product_info.php/cPath/52/products_id/97
  14. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
