Changing F1 gearbox fluid | FerrariChat
Discussion in 'Technical Q&A' started by CavalloRosso, Oct 28, 2007.
  1. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    I posted this in 345/355 section but I'll post here as well...how hard is it to replace the f1 gearbox fluid? Is it hard bleeding the system? Also, what fluids have people used? I'm tempted to replace with fully synthetic fluid as the recommended Shell Donax TX is semisynthetic from what I understand. Any help (especially with instructions) would be appreciated.
  2. CavalloRosso
    Jul 12, 2007
    1,423
    SVO
    Wow. 50 views and no response? Is it hard to do or are people just being lazy?
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #3 No Doubt, Oct 30, 2007
    Changing the F1 gearbox oil (not to be confused with F1 hydraulic fluid) looks quite like changing the tranny oil on the 348: http://www.club348.com/technical/Tech/348.html#ClutchTransmission
    Open #21 first, drain via #22, and check the level via #28 (see pic below):
    Now, if your question is instead about the F1 hydraulic fluid, then drain it, fill it, and finally bleed it via this procedure: http://www.ferrarichat.com/forum/showpost.php?p=135632782&postcount=7
  4. CavalloRosso
    Jul 12, 2007
    1,423
    SVO
    As always, you're a gem....thanks.
  5. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    #21 comes out first? I never got that far, couldn't get #28 out. So to that point, make sure you try that first THEN open the drain plug, just in case :D I'm going to change mine when the engine comes out this winter for the major.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Right. You want the fill plug to be open first because if you do it the other way (i.e. draining first) then you might get stuck being unable to refill your tranny.
    So you open #21 first to make certain that you can fill her up, then you remove #22 to drain (preferably when hot...or letting her drain overnight).
    #28 shouldn't be on tight at all, though. That's your tranny dipstick plug!
  7. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    ok, I thought you refilled through #28. Either way that thing didn't budge with a ton of torque (not literally); one thing working against me was the long chain of extensions to get down there. Anyway I'm happy, driven like a dream all summer!
  8. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Well, in a pinch you *can* refill through the dipstick plug #28.
