CHANGING IDLE JETS | FerrariChat
CHANGING IDLE JETS
Discussion in 'Technical Q&A' started by rcraig, May 14, 2006.
  1. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Have come to the conclusion that I need to change the idle jets on 79 308. Took the air cleaner off ( man much more of a PITA than I expected) 55 idle jets installed. ordered 60's. When I change these should my idle adjustment change and do I need to do this putting aircleaner back on or not? .-Bob
  2. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Short answer 1: Not neccesarily - if the needles are kept constant they generally all are richer to the same degree.
    Short answer 2:Not neccesarily. Should leave air clener off when first starting the motor with the new idles to check for leaks.
    It has been my experience that if you touch nothing else in the linkage, the idele will be quite sinilar abd just the one odle set screw in the middle will do.
    60's are quoite rich and you may expect smoe blue exhaust (very rich). Your transition will be smoother and you will definitely not need to use the starter enrichment when you start - at any temperature - if the rest of the carbs are stock and operational.
    If you are having a transition stumble around 2800 0 35oo, I would suggest you consider keeping the 55 idlea and raising the main jet size instead which will bring in the main circuit earler.
    Good luck and let us know!!
    best
    rt
  3. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    What is the easiest way to check for leaks.- Thanks for info
  4. thecarreaper
    thecarreaper F1 World Champ
    18,125
    Savannah
    60's are very rich and may require a hotter plug, say NGKBP5. i ran 55 /135 idle and main jets in all of my carb cars. i had the individual air filters on 2 of them. i would be careful to keep an eye on your plugs as 60's in any of my cars gave me fits. i would be inclined to increase the main jet and go to a richer air corrector before putting such a large idle jet in.
    my .02
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I tend to agree...on a '79 308, the cams are pretty mild and I would be surprised if you really need .60 idle jets. The early 308s ('76-'77) often respond well to .60s because of the cams, but I would suspect that .60s on a '79 would be really rich. Of course, you can tweak down the idle mixture screws to lean it up at idle, but once you start opening the throttle you get the full idle jet mixture. This should help your transition but it may foul plugs like crazy.
    I would just check the synch at idle once you change the jets, and then set the idle speed before putting the airbox back on, just to test things out.
    Birdman
  6. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Now I'm really confused. I was going to richer idles after reading page after page of chats about the need to richen the idle jets because of Ansa exhaust and removal of cats and air pump. I now think I won't even touch it, because it stumbles on the low end and runs very strong at mid-range and full throttle ( which I would havethought would be mains). Ok now I've lost all my confidence and will put the thing back together and run it crappy until I have the money to pay algar to screw with it for a day or two.
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    But imagine the education and confidence you would gain screwing with it a day or two by yourself!
  8. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    I am running 55 idles but I think it would be worth at least trying the 60s. They aren't that expensive plus it doesn't take long to change them. If I had a set I would give it a try. Change them out and drive the car. It is runs better keep them in if not change them back to 55s. IMO it is worth trying.
  9. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    It's absolutely worth trying the .60s. I am just surprised if a '79 wants .60s but hey, what the heck do I know??? It won't hurt anything. Worst case, it runs a bit rich.
    My '77 loves the .60s and everyone told me they were too rich too. It might be, but the car runs better with them without a doubt.
    Birdman
  10. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Furthermore, it is my experience that most dealerships (yes even Ferrari) and most independents (I'm sure not all) haven't the slightest idea what they are doing with carbs anyway. Maybe Algar has a carb guy that knows his stuff, but there are very few shops locally in this area that have anyone that knows squat about Webers on 308s.
    Birdman
  11. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Thanks for all the input guys. When I left for work this morning, I was not enthused about the whole situation, now upon return I went ahead and ordered .60 idle jets. You're right since I got this sucker apart I'll go ahead and try them.. By the way i checked mains since it was so easy and they are 125, emulsion tube F36. Any thoughts?
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Would consider 135 mains, F36, 200+/-10 Air correctors and 55 idles. This will save some gas, but yet bring in the main circuit sooner.
    Good luck!
  13. thecarreaper
    18,125
    Savannah
    exactly. this is a near perfect combination. . 60 idle jets are too big for a 308 with no internal engine mods. i gave away the set of them that i took out. jets, spark plugs and accuracy of the advance wieghts in the dizzys are critcal to a happy carb car. i detest points ignition, so that would be another point to improve upon.
    been looking for another carb 308, havent found one i like yet. lambo is gone, the 911 is fun, but it aint no Ferrari. it is cheap to play with though.
  14. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    Currently, my '78 has 135 mains, F36, 200 AC and 55 idles. I do have a set of 60 idles that I will try when I get a chance. It is a simple job to R&R the idle jets. I do have individual filters, opened exhaust (no muffler), and an Electromotive ignition.
    Henry
  15. jaydens1
    jaydens1 Rookie
    May 17, 2006
    33
    new zealand
    tony j downes
    it probably sounds a bit out there but have you checked any of the other basics.cap ,rotor grounding out.ht leads plug condition and gaps.do you do alot of short runs.try closing the plug gap by .004 .a closer gap will give you more spark duration.if that fixes it the coil could be weak.if its a flatspot check your accellerator pump .is it pumping to little.too much can give you a similar feel as you have too much fuel mixed with a certan amount of air.get the emissions checked out.it will tell you alot
  16. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    NO muffler??? WOW! That sucker must be LOUD!
  17. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    WHAT?!? Did someone say something? ;)
    Actually not too bad. I've got the cats on and the Ansa tips muffle it a bit. It's a little louder than some Tubis I've heard on 308s.
  18. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Well put the .60 idle jets in and she runs like a cat on fire.(that's a good thing.) I must say though you guys think this crap is easy I think you're nuts. Not that it is too dificult mentally, but I'll bet it took at least an hour and a half just unscrewing the jets and then screwing them back in. I guess yoursare the same, but for all the inside jets there is only about 1 inch of clearance between plumbing running between carbs and jet. What the hell are you guys using to unscrew this? I also learned that if you remove o-rings and thread on jet and then rub spit for lube arount ring it goes in real easy. If you leave the o-ring in the carb it's a real bear and you risk slicing the ring. I just couldn't get them to change smoothly on the inside jets. My kids have a much larger adult vocabulary now.
    Anyway everything seeems to have worked well, but my idle dropped to around 600 from 1000. This is the opposite from what I expected. I thought it would rise.
    The stumble is 99.999 percent gone and backfire also non existant. Seems to run very strong and much smoother and easier to match revs with heel-toe downshifts.
    Thanks for everyone's help. Soon I will begin working on slight breakup at 6300 or so. By the way electricals have been completely rebuilt at major service about 4 thousand miles ago and then timing and advance checked by Algar in Philly about 3 weeks ago. They did say my advance switch was not working properly and that they fixed, but I didn't notice any significant difference.
    Any thoughts on the idle drop. Idle is consistent, just slow.
    Bob
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I had to smile hearing you talk about the inside jets. I also have developed a new vocabulary. I made a dinky little tool just for those with a removable screwdriver head and a socket and some tape. I am also glad tha Pierce sells the little o-rings cheaply. I keep a supply.
    Glad to hear it went as expected. Richness covers up that transition between idle and main circuit making it much more livable. As I said before, you may eventually want to try 135 mains and back down to the 55 idles.
    That slight break-up is probably in part due to those 125 mains you are running. If you are set on keeping the 125 mains, would suggest richening the top end with an air corrector of about 190 or so.
    Your idle went down as it is a bit richer than it was - my A/F bet is around 11:1 to 12:1 from 13 or higher.
    Again - glad to hear it is improved - keep us informed!!
    best
    rt
  20. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Alright! Good work Bob! Now sync the carbs and tweak the idle speed! What teh heck, the airbox is off anyway.
    I have this fabulous 90 degree screwdriver that I have had for eons and I use it EVERY time I work on the 308. I'll post a pic. Very helpful tool!
    Birdman
  21. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Thanks for the encouragement and help. By the way the airbox is all back on and everything secured. Honestly I was afraid to do any real driving with stuff apart, and that ment a real drive because I really wanted to know how it worked. So for now I will leave it alone and drive for a week or two as to get to know. Russ, I have no great affinity to 125 mains and plan to try larger, but I believe I should only make one change at a time and reevaluate. My time in R&D at a science company tells me to take it slow and really evaluate what changing one parameter does before changing another.
    This will sound stupid but if I take the airbox off can I adjust all 8 idle adj screws the same amount if it seems to be running consistant now. I assume I must back out screws. Without airbox how do I know what idle will be like with box back on. I have to assume there would be a significant difference in idle with or without.
    Since the valve in the end of the airbox seems to be missing. I see no big butterfly looking thingy, is the small hose out of bottom of airbox on right side that hooks into the little filter thingy and then runs into the big cannister thingy important. Can it be removed? I was thinking of insulating the canister and keeping beer in it. It seems to be a drying canister for some bogus emmissions system that shut the aircleaner after shutoff and allowed vapors to be captured in cannister .Am I close.
    I must say for now the idle made a huge difference in the way the car drives and how much more torque it has. Before it would seem like it was hitting pretty hard after you got through the stumble, but seemed to be more noise and revs then power.
  22. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Hi Bob,
    OK, first the idle. There are only two screws to adjust idle speed. These are the throttle stop screws, one on the forward pair of carbs, one on the rear. They just allow you to adjust how far the throttle will close when you take your foot off the gas pedal. They must be adjusted together and is best done with a flow meter so you can get them matched from front to back. This is the final step in syncronizing the carbs. I HIGHLY suggest that you take another hour once you have the airbox off and do the sync procedure. Really, it's quite easy, just follow my guide and do it outside so you don't asphixiate. I PROMISE you will notice the difference. It's a nice feeling to know that the carbs are synched and you can feel it in the way the car drives.
    Adjust your idle FULLY warmed up, not just a drive around the block, or the idle speed you set will not end up there when the car is warm.
    Once you have adjusted the idle once with the airbox off, so you know the linkage, it is possible to do it with the airbox on, using a long screwdriver, a flashlight and a mirror. It's not easy that way. I would still pull the lid off the airbox and use the flowmeter to get the front and back balanced. That's the best way to get it to idle perfectly.
    The flapper in the airbox is to keep the stinky fuel smell from wafting out of the carbs into the atmosphere and the door is activated by a vacuum from the carbs, the same vacuum that runs the rest of the vapor recovery system ( i.e. the cannister you refer to). You can remove the vacuum line to the airbox, but you must plug the orifice that feeds the line, or you will have a vacuum leak and the car will run poorly. The cannister also is part of the fuel tank vapor recovery, so you don't want to remove it. It is harmless except adding a few ounces to the weight of the car. It actually does do something, which is to help keep your car from giving off fumes. You will appreciate it when your garage stinks of gas.
    Congrats on your progress! You are on your way to being a carb guy!
    Birdman
  23. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Birdman- Thanks alot for the encouragement. I wouldn't have even tried if it wasn't for some of the people on this chat backing me up. By the way I'm really anxious to put your fuse box on , but I don't have the dough now. I will get there someday though. I keep dropping hints to my kids that fathers day is coming up soon and reminding them how lucky they were to happen to get the very best Dad allowed by law.
    Also, the flapper in the front of the aircleaner that is supposed to close is missing in action. I guess the guy before me removed it, but all the vacuum lines are still there the best I can tell.
    Plus I must say that the scariest part of the whole carb thing was after you tried to put the airbox back on and couldn't figure out why it didn't want to fit right and you pulled it back up to peek underneath to see if there was a squirrel under there or something I nearly had a stroke worring that those little metal rings that go over the studs and into the black gaskets would fall into the carb throats. After routing the hose wrong about 8 times I almost superglued them to the black gaskets.
    Sorry to ramble, but can you explain the reason that if you put larger idle jets in the idle drops. It seems it would go up. Is it flooding of sorts by letting in more gas and not more air? Thaanks - Bob
  24. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    It all depends on what the mixture was before and what it is now. There is a happy medium in the ratio of air and fuel. When you change jets, you change that ratio and everything changes. You probably made it a little too rich at idle (for which you can compensate with the idle mixture screws) and that made it drop in idle speed. I find that my car likes to run a little better around town with a larger idle jet, which makes it a little rich at idle. So you make a performance trade off. I'll bet if you close down the idle mixture screws a turn or two, the idle speed will come up again. It's important to note that the idle mixture screws only adjust the fuel delivery at idle, with the butterflies closed. The progression circuit that feeds additional fuel in the transition period between idle and the main jets is VERY important to how the car runs, and those are fed directly by the idle jet UNAFFECTED by the mixture screw. If you look at a cutaway diagram of the carb, you will see what I mean. The fuel to the progression holes goes in a different path from the idle jet AROUND the mixture screw.
    Once the idle mixture screws are open all the way, the idle mixture is limited by the idle jet. So if your car needs more fuel in the transition period, the only thing you can do is a bigger jet. Then if that makes the idle too rich, you just close down the mixture screws and lean out the idle mixture. In fact, the way you set idle on the car if you don't have an exhaust gas analyzer is to set the idle screws for the point at which they produce the highest idle speed. That is, in theory, the ideal setting where the A/F ratio is optimum. You would be surprised how close you can get it this way if you are careful. If you close them to much and go too lean, the engine slows and if you open them too much and go too rich, the engine slows. At the right setting, you hit a peak in the bell curve where the engine runs best.
    Birdman
  25. rcraig
    rcraig F1 Rookie
    Dec 7, 2005
    2,960
    Maryland
    Bob Craig
    Do I screw idle mixture screws in or out to raise idle. Can I assume this really only affects either air or fuel. Screw in- less air, screw out -more air or screw in- less fuel,screw out- more fuel. Just trying to understand how it works. Hypothetical== bigger idle jet-too much fuel at idle so idle goes down. If screw controls air then if I screw it out it would let more air in mixture leaning out.
