Changing testarossa center wheel cap | FerrariChat
Discussion in 'Technical Q&A' started by Longhorn, Jan 28, 2016.
  1. Longhorn
    Longhorn Rookie
    Dec 15, 2014
    13
    One of the center wheel caps on my 1990 Testarossa was cracked so I ordered another. (The car is the newer model with 5 lug nuts and not a center knock off.) What is the best/easiest way to put on the new cap? Do I need to remove the wheel?
    Thanks/Jon
  2. Rifledriver
    37,090
    If you don't care about the cap that is in there now, stick a screw driver through it and pop it out. If it is an early style cap it is a tight fit but the rest of the pieces can be removed and the new one installed at that point and the wheel does not need to be removed.
  3. Longhorn
    Longhorn Rookie
    Dec 15, 2014
    13
    Thank you. I will give it a try.
