Changing the steering ratio | FerrariChat
Discussion in 'Technical Q&A' started by Aircon, Nov 20, 2003.
  1. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I was told tonight about what was described as a "miniature gearbox" that is fitted into the steering column that changes the steering ratio. Anyone know about it? Seems like i could get my ratio changed from the current (and ridiculous) 2.75 turns lock to lock to maybe 2 turns without changing the rack and power steering pump.
    Comments anyone on where to get it, how much it is, and if it works? I fail to see a downside.
  2. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Yep.
    Go to the next grasstrack/speedway meet near you. You'll see half the field use an epicyclic cluster from an overdrive unit or butchered auto box to up the gearing.
    You simply weld or match on your appropriate column attachments and go racing. It's as crude as you get, but very effective.
    You need plenty of room for installation though, as the units are typically around 150mm diameter.
    Not really very "Ferraristic", but ingenious none the less.
    Better off getting a rack/pinion built and a power steer specialist to adjust pump pressure/delivery accordingly.....not that hard.
  3. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    Peter,
    There is an optional quicker ratio rack for F355 Challenge. Issued in 1997 when the wing came out, it was part of the update package mandatory for continued participation.
    • Wing
    • Rack and new power steering pump to match
    • Oil to air oil cooler mounted up front with ducted air from the driving light housing (replacing oil to water in the V of the engine)
    • Removal of the headlight assembly and motors, replaced with housing shells only
    • Alternate larger front and rear anti-roll bars
    If you have those other components on your Challenge, you may also have the rack too. I don't have specific part numbers or specifications.
    If you have the history of the car, you may find the information there.
    Best regards,
    Rob Schermerhorn
  4. Aircon
    100,524
    Peter
    Rob, I don't have that rack, but i've driven a car that has it and the reality is that it reduced lock to lock from 2.75 turns down to 2.5 turns. I want a bigger difference than that. More Porsche like, to be frank. I love the steering in a 550/575 and that's just over 2 turns lock to lock. The updated rack for the '98 challenge is a waste of money for me.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    mk e,
    Any chance you know what splines the 3x8 series has?
    I'd love quicker steering, even if the force increases.
  7. Aircon
    100,524
    Peter
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,805
    The twilight zone
    Verell,
    I don't know what splines are in the 308s. I don't have one of those, I just remember seeing them and it seemed like what Aircon was looking for.
    I don't know know how big the gear box is. I'm sure it can be installed in any car if you're pigheaded enough, but I'm also sure it won't bolt in. The steering columb probably needs to be cut to fit it. I've see weld on splines in race chassis catalogs, coleman has these:
    http://www.colemanracing.com/section/index.htp?id=56
    http://www.colemanracing.com/section/index.htp?id=32
  9. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I purchased the quick turn rack and pinion set for my 308, from Superformance in the UK.
    I had planned on installing it while rebuilding my steering rack last week, but I unfortunately injured my hand and have yet recovered enough to turn a wrench.
  10. Aircon
    100,524
    Peter
    Excellent. Thanks
