Changing water temperature gauge in '85 308 | FerrariChat
Discussion in '308/328' started by Will Hornsey, Dec 8, 2022.
  1. Will Hornsey
    Will Hornsey Rookie
    Nov 7, 2021
    15
    The water temperature gauge is located at the top of the instrument panel.
    My question: Do I have to remove the steering wheel (I would prefer not to; I do not now want to screw it up) in order to change the water temperature gauge? It looks like there may be enough room to not remove the steering wheel.
    Thanks.
  2. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    It would be easier w/o the steering wheel in the way.
    I would think those six allen screws would be real easy way to remove the outer part of the wheel, without pulling the hub.
    Doug
  3. Will Hornsey
    Will Hornsey Rookie
    Nov 7, 2021
    15
    I agree it would be easier without the steering wheel in the way. I read that after I remove the 6 allen screws, I would need a steering wheel puller? Is there more than 6 allen screws holding the steering wheel on? What does it entail to remove the steering wheel?
    Thanks for your input!
  4. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    748
    Omaha, NE area, US
    Steve
    If you remove the 6 screws, the wheel will come right off (lift the horn button off first and disconnect the wire to it. It has a simple plug). It's only if you are removing the hub to which those 6 screws go into that you might need a hub puller.
    Steve Magnusson likes this.
  5. Dr Tommy Cosgrove
    36,450
    Birmingham, AL
    Tommy
    If you spend more than 1 minute removing the wheel, you are slow.
    thorn likes this.
  6. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    While you have it apart, it’s a good time to replace or update the bulbs ( leds). Also, clean up the grounds.
  7. Will Hornsey
    Will Hornsey Rookie
    Nov 7, 2021
    15
    Thanks everyone for your input!
