Chapter Three /Gearbox Oil Change on the 308 GT4 | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by robertgarven, Sep 6, 2006.
  1. ragtop1
    ragtop1 F1 Veteran
    5,273
    Ontario
    Larry Warren
    Robert, Thank you for the tutorial. However, my manual says to use 4 quarts of gear oil. You have indicated 6. Please explain the extra 2 quarts. thanks. '79 308
  2. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    I just pour it in till it comes out the back hole then I shut it up and add I more quart. The high gears get starved for oil and it was a Ferrari tech who suggested it. I also run and extra quart in the engine to prevent starvation on corners 20+ years and no problems.... I am not an expert though...... just my 2 cents!
  3. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    562
    London
    Anthony Bentley
    Sorry to drag up an old thread is it GL4 or GL5 75-90 redline.
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    In my 1982 308GTSi RedLine GL4 MTL. Many others will chime in .......
  5. GordonC
    GordonC F1 Rookie
    4,169
    Calgary, AB, Canada
    Gordon
    It is GL4 - there are no hypoid gears in the 308 transmission/differential unit. It's hypoid gears, like in a traditional differential, that require the EP extreme pressure additives in GL5.
    I tried the Redline 75W90/75W90NS mix that has been recommended here, then changed to Redline MTL as recommended by Rifledriver - I found it shifts better with MTL, a GL4 fluid.
  6. Bhagwan Phagash
    Bhagwan Phagash Karting
    Jun 13, 2005
    54
    Hampshire UK
    This is a very useful article, thank you. I recently did an overdue transmission oil change and miraculously the filler did come undone, somehow.
