charging battery | FerrariChat
charging battery
Discussion in '348/355' started by F355Bob, Aug 22, 2014.
  1. F355Bob
    F355Bob Formula 3
    I have a 95 F355. There are three terminals in the engine compartment box that contains the plus terminals. Does it matter which terminal you use to connect the plus side of the battery charger?
  2. tomw
    tomw Formula 3
    Feb 25, 2004
    2,413
    London
    Tom
    No.
    I always use the middle one for some reason.
  3. NSXn355
    NSXn355 Rookie
    May 3, 2014
    48
    Northern NY
    Bill
    The three terminals come off a common bus bar so it really would not make a difference. One (rear?) is from the battery while the other two connect to the alternator and starter motor independently. This arrangement allows the starter and/or alternator to be disconnected without disconnecting the battery as opposed to have them all stacked up on a common post.
