Charging Cable in F12: Where? | FerrariChat
Discussion in 'F12/812' started by Principissimo, Oct 9, 2021.
  1. Principissimo
    Principissimo Formula Junior
    Sep 14, 2015
    838
    Milano
    Bruno
    Every time I close the trunk on my F12, while charging, I’m always afraid to cut the cable
    Can you tell me where do you put the cable in order not to ruin it?
  2. blkfxstc
    blkfxstc Formula Junior
    872
    TX
    Eric
    Same corner as the plug, make sure the cable is flat before you shut the trunk.
  3. Principissimo
    Sep 14, 2015
    838
    Milano
    Bruno
  4. JimDowd1
    JimDowd1 Rookie
    Jan 23, 2021
    23
    Pacific Palisades, CA
    James Dowd
    I do the same. So far no problem.
  5. ERIC ANDERSON
    ERIC ANDERSON Rookie
    May 3, 2020
    44
    Cleveland, OH
    Eric Anderson
    Had similar concerns. Ran it out of front passenger window.
    Best solution I’ve been told is to not use it and use a conventional Battery Tender straight to the battery. That’s what I’m doing now and it’s great. Hard wired cable to battery charger comes out by the wiper.
    smagee, SeattleStew and Bobby_P like this.
  6. SeattleStew
    SeattleStew Formula 3
    1,019
    In the rain
    Stew
    This is a much better long term solution. Most higher end electronic shops can also make a port similar to how it is on the 812s and put it in the rear bumper. Lots of options, just depends on the $$ spent.
  7. smagee
    smagee Rookie
    Apr 13, 2021
    12
    Steven Magee
    I do exactly the same and it works great.
  8. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,581
    Grant
    Don't shut the lid down fully, the lights in the boot/ trunk will go out after 1/2 an hour.
    eskanday likes this.
