Charging the 458 | FerrariChat
Charging the 458
Discussion in '458 Italia/488/F8' started by Beefcake2001, Apr 24, 2016.
  1. Beefcake2001
    Beefcake2001 Karting
    Dec 5, 2013
    105
    Hi
    Just bought a 2013 Rosso Scuderia Ferrari 458 spider here in the uk.
    Car being delivered on 14th May.
    Where do you guys route the wires when you leave the car on the charger ?
    If they come through the door like some I have seen does this not damage the door seal or
    The charger cables.
    My car will be in a secured garage. However I would still like to be able to lock the car with all doors and windows shut and it being charged.
    Many thanks
  2. TC94
    TC94 Formula 3
    Aug 23, 2005
    1,292
    TN
    Under the passenger door. I've done that for three years almost year round without problems. Just don't route it through the forward vertical or door curve.
    It's what the factory recommends.
    bball16 likes this.
  3. Beefcake2001
    Dec 5, 2013
    105
  4. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    As above with the following caveats. Pull the wire as close to the front edge of the door (near the front fender) as possible, then close door. Then, advance wire forward the last inch or so and it will have no pressure on it. You will be able to wiggle the wire freely in this position.
    When removing the charger wire you will have to pull it back that inch or so. Otherwise, the wire sometimes gets hung up in the door/fender area when you open door to remove charger. I have been doing this for the past 6 years on my Italia and spider with no wire/charger issues.
    Best.
  5. agentbb007
    agentbb007 Karting
    Sep 25, 2009
    63
    Strider
    I just lower the window a little and run it out that. But if you find a good/easy way to run it out the door upload some pics so I can try it that way :)
  6. justthebest
    justthebest Formula Junior
    May 14, 2014
    319
    Denver, CO
    The manual describes the passenger door location, and you can see where the actual metal is curved to allow the wire to sit without significant pressure.
    14RE458 likes this.
  7. rickwjenn
    rickwjenn Formula Junior
    Mar 8, 2012
    544
    Minneapolis
    Rick
    both ways work great.
    I learned the hard way, REPLACE the battery after 2 years or so. This "Charger" is only a conditioner and will not raise the voltage on the battery. As the battery ages, the conditioner only holds it at that reduced voltage.
    This cars will start shifting abruptly, miss the rpm matching, and will even get the transmission failure light due to aging battery - even if it was on the conditioner each night as was mine.
  8. Doug_S
    Doug_S Formula Junior
    Apr 8, 2007
    450
    NJ
    Doug
    Yes, There is a spot for the wire. I think the official way to do it is to close the door on the wire while it is near the front of the step plate, then pull the wire from outside of the car forward until it hits the groove. You can feel for the groove on the passenger door seal when the door is open. You can definitely feel the groove when you hit it pulling the charger wire from outside the car.
    Low battery major problems. Three days after I bought mine I was driving to an event and doing some spirited corners when the car shut down and went into limp home mode. After sitting at the event it drove ok but afterwards it would go into limp mode every so often.
    Took it to the dealer and bad battery. I got confused about the estrimate and told my wife it is only the battery and costs about $200. She said "Nothing on that car costs $200." She was right.
  9. spiders
    spiders Formula Junior
    Jun 8, 2012
    474
    Are the 488 cars as sensitive to battery voltage variations as the 458 appears to be?
  10. Caeruleus11
    Caeruleus11 F1 World Champ
    10,892
    This is all correct. I move the wire a little each time...
    I also replaced the factory tender (made by CTek) with a CTek 7002- it will do a great job with the battery.
  11. Aeroengineman
    Aeroengineman Formula Junior
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    I believe my Ferrari charger has failed as it seems to run down my battery, rather than charge it. I looked at the end fitting of the Ferrari charger and it doesn't look anything like the ones offered by Ctek7002. How do you use the ones from Ctek to charge your Ferrari?
    Thanks,
    Dave
  12. wthensler
    wthensler F1 Rookie
    3,152
    Gator Country, FL
    William
    + 1 for CTEK. I have the 500 series, works great. Works exactly like Ferrari one. I actually think Ferrari rebrands CTEK.
    + 1 for info about battery. I don’t think they even last 3 years. I started getting weird messages upon startup, so I knew battery was getting weak.
    + 1 for wire through the door, but honestly I don’t the door seal is all that tight to start with.
    Enjoy your car in good health!
    Caeruleus11 likes this.
  13. Aeroengineman
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    But this doesn't answer my question about the proprietary connector Ferrari has versus what Ctek provides?? My battery is an identical AGM battery that is only 8 months old. I just drove the car for 1500 miles 6 days straight with all voltages normal and battery read 12.6 V - then I hooked up my Ferrari charger left for a week and came back with the battery drained to 11 V where upon I got the warning of a major electrical system fault (caused by run down battery) - After the second try the engine started and I drove it over to the gym and back and battery is back up to 12.6 V.
    My question is how do you get around the proprietary connector and not destroy the "Ferrari" charger for Concours De Elegance scoring purposes by adapting the Ctek charger?
  14. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,305
    South East
    Jimmie
    There are previous threads about adapters on Ebay or you could unscrew the existing lead and put in the new CTEK & reverse the process on the few days your concours mark is critical - much the same as you put back into the tires the genuine Italian air on those days
  15. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    818
    San Diego
    Rob Barry
    Some people make their own, some people buy off Ebay. I bought off Ebay and have been very satisfied: https://www.ebay.com/itm/Ferrari-Battery-Charger-Custom-Adapter-for-CTEK-360-F430-458-California-599-612/192316637726?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3D70323c4c84ac4975a92d2f811404dc5c%26pid%3D100623%26rk%3D3%26rkt%3D6%26mehot%3Dag%26sd%3D192326010880%26itm%3D192316637726%26pmt%3D0%26noa%3D1%26pg%3D2047675&_trksid=p2047675.c100623.m-1.
  16. wthensler
    wthensler F1 Rookie
    3,152
    Gator Country, FL
    William
    The 458 charging connection is under the dash, on the right hand side. CTEK sells the Ferrari 458 adaptor, which connects the CTEK to the dash. It’s basically a piece of wire......
    Graz likes this.
  17. RWC58
    RWC58 Karting
    Oct 14, 2018
    154
    Columbus Ohio
    Robert W Crooks
    Well my battery is 2 years old and weird messages on start up and I have had the limited engine performance message come on which is posted in another thread.
    sounds like the battery is a concern but it has been on the Ferrari factory charger and the center half charge light has been on for hours . I didn't realize that it was only a conditioner and not a charger . Next question is which model of c tek do we buy ?? The company has a bunch of offerings and I'd like to make an intelligent decision.
  18. Aeroengineman
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    I called ctek this morning and they said they would rebuild my ferrari charger/conditioner as it was proprietary even though it was theirs I had to see the dealer. He did say their replacement was MXS 5.0 and the Ferrari Adapter is being sold by 3rd parties for about $60 on Ebay. Sure enough I ordered the Ctek and the recommended unit for a total including tax was $164.00 and I'll have it by Friday. Called the dealer and they wanted $469 plus tax. So I'm going to use the Ctek and put the Ferrari unit that doesn't work in the red bag it came in for the Concours in Portland in 2021.
    rob5819 likes this.
  19. Aeroengineman
    Oct 5, 2003
    897
    Maple Valley, WA
    Dave Tegeler
    ... would not..
  20. docf
    docf Formula 3
    Sep 14, 2008
    1,356
    Florida
    Gary
    Buy the Cytec 7202 It much better unit. It's not more than 100.00. So much more features.
    Graz likes this.
  21. tr328
    tr328 Formula Junior
    Jun 19, 2003
    905
    Pacifica, California
    Darryl
  22. docf
    docf Formula 3
    Sep 14, 2008
    1,356
    Florida
    Gary
    Run The "Pigtail" cordage to the extreme front of the bottom of the front passenger door as there is a space there to handle the width of the pigtail. If you use the plug in cordage and the area on the door shown you will fracture or cut the cordage.
  23. thebigo
    thebigo Karting
    Feb 10, 2019
    79
    There is a much better place at the top. Bring the cable in at the top edge of the fender just beside the door/fender gap.and route it down near the door joints.
