Charging with Extension Cord | FerrariChat
Discussion in '296' started by cmargosi, Nov 3, 2025 at 11:37 AM.
  1. cmargosi
    cmargosi Formula Junior
    451
    60540
    So, I'm anticipating the delivery of my 296 sometime this winter (it's at 85) and living in Chicago I'm sure I won't want to be driving the car when it arrives.
    Somewhere along the line, I thought I read or heard that you can not use and extension cord with the charger. Is this true? Anyone have experience one way or another?
    jm2 likes this.
  2. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,484
    michigan
    john
    I’ve used a heavy duty extension chord for over a year with no issues. I believe the ‘recommendation’ is to not use one, but my experience has produced no adverse effects. Live in Michigan with the resulting weather conditions.
    What does your dealer say?
    Caeruleus11 and ShadowLAP like this.
  3. ferrefeh
    ferrefeh Formula Junior
    273
    Illinois
    Feh H
    Use a 12 AWG extension and it’ll be just fine. Car will charge at 12A on 120V from what I’ve seen
    I’m using a 14 gauge but it’s about a 12 ft distance total.
    ryalex, Caeruleus11 and ShadowLAP like this.
  4. cmargosi
    451
    60540
    I have question into dealer because I can't remember if they told me or it was someone else. What side of the car has the charging port? Trying to figure out if I need to have an outlet installed in the garage before it gets too cold, as well.
  5. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,484
    michigan
    john
    Drivers side for the charge port.
    ShadowLAP, cmargosi and of2worlds like this.
  6. cmargosi
    451
    60540
    Dealer has told me that you are not supposed to use an extension cord. I have now asked the length of the included cord and he said he thought 20 feet but will get back to me.
  7. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,484
    michigan
    john
    Better do what the dealer tells you!
    x z8 and ShadowLAP like this.
  8. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,484
    michigan
    john
    I should have been more specific, driver side on US vehicles.:rolleyes:
  9. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    605
    SW Suburbs of Chicago, IL
    Lawrence P.
    Thank you for checking with the dealership on this.
  10. ferrefeh
    273
    Illinois
    Feh H
    It's lowest common denominator advice, if one understands electricity and circuits and you use the proper size wire gauge for an extension (and rated outlet) it should be no problem. But the majority do not, so that's the advice that is given.
  11. Caeruleus11
    Caeruleus11 F1 World Champ
    11,797
    One thing you should also remember, every few weeks, Id say 3 or so, unplug the charger from both the wall and the car. Wait a few minutes, then replug. This resets the computer in the charger and in the car.
    ShadowLAP, 599F1 and x z8 like this.
  12. rbobby
    rbobby Karting
    Aug 13, 2014
    105
    I would add that if you're adding an outlet for charging or have one that you will use in mind, be a bit careful about what other device/ outlet shares the same circuit. Most circuits are rated for 15amps. Ferrari charger will draw quite a bit of current when it gets going. You want to avoid another device getting in the way. I have had a few instances where my circuit breaker tripped. So I believe the charger can dance very close or even exceed the 15 amp limit. Next house I'm moving to, I'm putting in a dedicated 20 amp circuit for this.
    Be sure to check on the car every few days if you're putting it away for the winter. If circuit is tripped, you're not getting charged obviously.
    SAFE4NOW, gqa, x z8 and 2 others like this.
  13. Cocoloco
    Cocoloco Formula 3
    Nov 26, 2013
    1,683
    #13 Cocoloco, Nov 4, 2025 at 5:56 AM
    Grab 20a 12gauge cord - use only the length you need to make it work, longer cord more power drop.
    Put on dedicated circuit or call electrician install - like a copier at the office same for hybrid Ferrari.
    There is a reason Ferrari has a robust heavy power cord. I would start the car as often as possible - breaking in a battery is a lot like breaking in an engine - the more variances the better.
    x z8 likes this.
  14. cmargosi
    451
    60540
    So here's the question, without having a charger in my hand. I'm thinking of having a dedicated outlet / dedicated 20 a circuit put in the garage, as this would allow me to charge not only the Ferrari but a future hybrid car (not at the same time, obviously). I have thought about a M5. The BMW chargers come with different wall plugs (one for a regular outlet and one for the washing machine type outlet). Do the kind folks at Ferrari include the same options? So hard to plan for this stuff when you can't even see what the charger looks like.
  15. x z8
    x z8 Formula 3
    Nov 22, 2009
    1,513
    Florida
    Jeffrey
    I have had this issue too. I changed my circuit to 20 AMPS.
    rbobby likes this.
  16. jumpinjohn
    jumpinjohn F1 Veteran
    7,931
    Texas
    I have my charger on a shared circuit, not dedicated. That circuit has about 6 trickle chargers on it, 7-8 supposed electronic rodent repellants. No problems so far, but I’m not using any extension for it.
  17. senseiturtle
    senseiturtle Karting
    Mar 4, 2024
    61
    Spartanburg, SC
    If you get the right extension cord, it'll have more electrical capacity than the house wiring from the breaker to the plug. Should be ok. Mind the distance though.
