Chassis tubes inner surfaces, treatment of: | FerrariChat
Discussion in '206/246' started by dignini, Nov 4, 2006.
  1. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    The chassis tubes on my car are in good shape. What about inside the tubes? What would be the best way to protect from corrosion from within?
  2. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,716
    26.806311,-81.755805
    Dave M.
  3. nerodino
    nerodino Formula 3 BANNED
    May 19, 2005
    1,161
    Suffolk UK
    Graham
    In the UK we have a product known as Finnigans Waxoil which you warm up to turn it to a liquid,then with the plastic hose type lance which is roughly around 5mm in diameter with a nozzle which produces a 360 degree spray pattern, drill as required or use existing wherever possible 6mm holes and merrily spray it in till it starts dripping all over you! then with the plastic plugs provided systematically plug up all your holes. Job done! only thing is if you leave it on your drive on a hot day sods law say's that it will find somewhere for the excess to escape onto your lovely drive. but at the end of the day it's widely known as the best product over here.
    BTW Don't Eastwoods do a similar system that they call 'rust encapsulator'?
    Regards G.P.
  4. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    Thank you G.P. I do remember fiinegans wax oil from my earlier days. As for the wax leaking out, makes a lovely pattern on a rainy day.
  5. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    What do you think? worth the effort or not?
