Cheap repair of a Speed Sensor Type 2 Vegilia (68 0517) | FerrariChat
Discussion in '308/328' started by craiggo, Aug 3, 2016.
  1. craiggo
    craiggo Formula Junior
    416
    Redwood City
    Craig
    #1 craiggo, Aug 3, 2016
    I have not seen this posted anywhere so I'm sharing to ensure this info gets out there.
    Like many of you, the speedometer on my '87 328 seemingly stopped working. Actually, it would work, then it would stop. Then it would get warm and start working again. Finally, it died for good.
    For those of you that went out and purchased a new sending unit, you might want to stop reading this post, right here.
    We were able to measure input/outputs and it wasn't working. My dad fully believed it was a bad transistor in the sending unit so we found replacements and were all set to replace them. After struggling for a while to get it open, it finally unlocked and we could see the innards.
    On a whim, my dad decided to reheat all solder joints. He retested and it worked! We resealed it, reinstalled and the damn thing has worked perfectly ever since.
    So before any of you go out and spend any money replacing these units, try this first.
    ellum likes this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    Great fix! Thanks for posting.
  3. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,757
    Boston, MA
    John E. Kenney
    Holy friggin crap! Same thing happens on Miata speed sensors. Those puppies were crimped though, and sealed with silicon. You can dremel out the silicon and then add solder but I decided to go ahead and pony up the cash like I did for the 348 sensor. Ferrari was easier on hand than Maserati but at the added markup. Got it done and then flew to Brazil. I just installed my new sensor in the Miata a couple weeks ago. Also replaced the Ford MTF since it drains out of the sensor hole too. I can't believe how silly these speed sensors are! I made a heat jacket for the 348 since it sits next to the cat. Miata sits next to collector on my 4-2-1 header ;) But I got 100K out of the old one. Can't see on the 360 but probably need hydraulic fluid for the top.
