Check Control Centre | FerrariChat
Discussion in 'Mondial' started by jpnel, Dec 29, 2020.
  1. jpnel
    jpnel Rookie
    Jan 6, 2018
    10
    John Nelson
    Hi, I am currently restoring the interior of my 308QV and want to replace the face of the check control centre that is scratched and faded. Has anyone had any experience in having the face replaced? It is relatively simple to remove but has anyone had a new face made?
  2. afterburner
    afterburner F1 Rookie Silver Subscribed
    Jun 20, 2008
    3,470
    Switzerland
    Urs STEMMLER
    Hi John
    Did they have that? I thought it's Mondial only. Any pics?
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    I know that jewelers can polish up watch faces, might be worth a look !!
  4. dmarti02
    dmarti02 Karting
    Jun 22, 2014
    52
    Haverford, Pennsylvania
    Doug
    If you are referring to the check control on the Mondial (not sure if that was a 308 feature), you can clean it up quite a bit by the following:
    1. Remove the check control. See forum for method as you must remove the connections from below the console. Don't pry it out from above.
    2. Tape off the outer edge (the painted metal portion)
    3. Get a foam buffing pad for your drill. I would suggest a white or black foam pad, not a heavy cutting one.
    4. Use a rubbing or polishing compound. I would recommend Meguiars 105 followed by 205.
    5. Polish slowly and carefully. Don't stay in one position to long as it's easy to burn plastic when polishing. Mine took around 6 passes with 105 an about 3 with 205. Followup with your favorite wax.
    6. You will lose the OEM "matte" finish, however, you should be able to get out most if not all reasonable scratches (i.e. those that can't be caught on a finger nail).
    If there is substantial fading or gouging, this probably won't work, but should make it better..
    Hope that helps!
  5. jpnel
    jpnel Rookie
    Jan 6, 2018
    10
    John Nelson
    My apologies all, I thought this was on the Mondial forum. Yes it is a Mondial. Will try the polishing but the colour on the underneath is also patchy. Regards
  6. afterburner
    Jun 20, 2008
    3,470
    Switzerland
    Urs STEMMLER
    There's some issue on the back side of the color spaces...
  7. afterburner
    Jun 20, 2008
    3,470
    Switzerland
    Urs STEMMLER
    The display surface is originally matt to stop reflections.
