Check Engine 1-4 light issue | Page 2 | FerrariChat
Discussion in '348/355' started by tcbquattroporte, Apr 20, 2020.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    2.7’s don’t need a code reader. For U.S spec, the code button is in their rear passenger engine. Need to remove lateral cover. The flashing lights are on the cluster inside the car. The check engine light will flash the codes in pattern. You have to count to the flashes to discern the codes.
    flash32 and 308 GTB like this.
  2. Qavion
    Qavion F1 World Champ
    14,674
    Ian Riddell
  3. jfink
    jfink Rookie
    33
    Charlottesville, va
    jon fink
    It was the O2 sensors and once replaced everything was good. Sold that car two years ago
    Qavion likes this.
  4. Suffyk
    Suffyk Formula Junior
    May 25, 2012
    319
    @jfink - replacing the O2 sensor fixed a 1121 code? From the Ferrari Workshop manual 1121 appears to be an RPM sensor. My car is currently reading a 1121 error across both banks (95 vehicle), but only Check Engine 1-4 is lighting on the dash.
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    You will always get 1121 if you read the codes with the engine is NOT running. If engine is running you should not get 1121 codes.
