Check Engine 5-8 light came on. | FerrariChat
Discussion in 'Technical Q&A' started by ferrame, Feb 12, 2006.
  1. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    What caused the check engine 5-8 light to come on after a short/normal driving. Then it idles about 1500 rpm when normal idling should be 1000 rpm.
    It's a 95 F355.
    Does anyone have any idea what caused it and how I can fix it?
    Thanks in advance!!!
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Well the first thing your gonna have to do is pull the codes out of the Motronic 2.7. I don't know for sure if it is same process as pulling them from the 348 Motronic 2.7. But you are still gonna want to pull the codes before you do anything else.
    As for the high idle, have you disconneted the battery lately?
  3. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    went to WWOC and they simply repalced the sensor (something I could have don myself cheaply had I known) and never happened again...but it could be many reasons, some costly so get the code and then the cure.
  4. Telerding
    Telerding Formula Junior
    Sep 30, 2004
    362
    Santa Maria/CA
    Tom Elerding
    I had this happen on my '95 F355 B at least twice. In my case it was the slow down light 5-8. Both times it was the connectors that interface with the ECU that monitors the catalytic converter temperature.
    Your problem could be similar: connector corrosion; but getting the codes is the best approach if you can do it. Given that your trouble includes high idle, it may not be as simple as mine.
    Have you done an archives search on this forum? I'd be surprised if this hasn't happened to others.
    Good luck
  5. ferrame
    ferrame Formula 3
    Mar 2, 2005
    1,196
    Orange, Calif
    Thanks so much for everyones' replies.
