Check Engine 5-8 | FerrariChat
Check Engine 5-8
Discussion in '348/355' started by vonzsolnay, Oct 19, 2018.
  1. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Hey guys, I have a 1995 355. I was driving the other day and the check engine light 5–8 came on briefly and then went off. It’s done that once or twice in the last day or so. It will come on, and then go off and then I don’t see it again for the rest of the day. Any ideas what this could be? Thanks so much.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Frank, it could be a variety of intermittent failures such as O2 sensors. Unfortunately, with OBDI, you don't have pending codes. Best thing to is check the code right when it goes on next. See attached.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    My recommendation is whenever you see those pesky lights, hammer down on the gas and drive it harder for about 10 minutes. It will go away.
    taz355 likes this.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    Does it come on at idle or at RPM? I can almost guarantee it will be a 1211 or 1212 code. Try cleaning the MAF for the 5-8 side. Check for vacuum leaks. Clean contacts for MAF. If you still have the problem, try replacing the 5-8 O2 sensor. Rockauto has OEM Bosch units fairly cheap, $70, BOSCH 13309.
  5. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,469
    Menlo Park, CA
    Paul Chua
    You can pull the code right? To see what is triggering it?
    Cheers
  6. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,469
    Menlo Park, CA
    Paul Chua
    If it is a 1211 or 1212, and cleaning it or adjusting the resistance doesn't fix it, let me know had both MAFs refurbished for this exact problem. Also make sure you check O2 sensors, easy cheap fix for that.
    Cheers
  7. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,469
    Menlo Park, CA
    Paul Chua
    You can always swap MAFs too and see if the light switches, then you know for sure it's the MAF.
  8. johnk...
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    355 MAF doesn't have adjustable resistance.
    paulchua likes this.
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,469
    Menlo Park, CA
    Paul Chua
    Hi johnk,
    I apologize or my mistake, I assumed the 2.7 Motronic ones had the adjustable plug. Appreciate the correction.
  10. johnk...
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    For reference, the 2.7 MAF is the same as a 1993 SAAB Turbo. Bosch no longer make new one but they remanufacture them. See below. Posted this before, but doesn't hurt to post it again.
  11. f355spider
    f355spider F1 World Champ
    18,044
    Check engine 5-8 or slow down 5-8?
  12. F355Bob
    F355Bob Formula 3
    Just check the code. I had one on 5-8 on and off on my 95. Checked the code and it was a temp sensor. Why guess?
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    That's funny Mitchell because in all seriousness I was going to post the same thing.
    Notmjust hammer down though, slow down to 20 then hammer down up to 8 grand through first 4 gears if possible.
    f355spider likes this.
