My car threw the below codes for the second time this weekend. Car is running fine and I cleared them about a month and half ago. P0410 - Secondary Air Injection System Malfunction P0102 - Mass or Volume Circuit Low Input I didn't get a response in the Technical Q&A section and wanted to see if anyone here has any ideas? Thanks.
Ck the fuse for the air inj pump and if blown replace it with a 30 amp fuse. It is a common problem and the factory recommended the fuse change.
Jody, the code reader I gave you with the car should only be used to clear the codes. The codes reported are not correct, or at least that is what I was told. I believe that you need the Ferrari reader to be accurate. I used to get a CEL from time to time and it was the same..... FoCF told me not to worry. Brett
