F8 - Check engine F8 | FerrariChat
F8 Check engine F8
Discussion in '458 Italia/488/F8' started by StevenF8, Jul 8, 2022.
  1. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Hi I got a check engine light today for the first time today I turned car off locked doors and reopened and started it again and it went off. It happened 2 more times I did the same steps and it went off. I’m running a novitec exhaust with stock cats and techtronic installed in December. Without bringing the car in any ideas what is happening? It does come on and off not sure if others have it go off after the CEL comes on or does it stay on did the dealer clears it?
    Any help is appreciated
  2. Viperjoe
    Viperjoe F1 Rookie
    Use a diagnostic tool (code reader) to determine what’s causing the CEL (I.e. Launch X431 29e)
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    mostlikely the exhaust upgrade
  4. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Which one would you recommend?
    If the code clears on its own would I still be able to see the error code on the reader ?
  5. Viperjoe
    Viperjoe F1 Rookie
    Yes, the code will remain in the ECU until it has been cleared.
  6. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Got it.
    Can you let me know which one I should get maybe an Amazon link please
  7. harrish1985
    harrish1985 Formula Junior
    452
    Miami, FL
    You likely have the same issue I had with the Novitec. Only alternative is a tune to remove the error codes. Where are you located?
  8. AD211
    AD211 Formula 3
    Owner Rossa Subscribed Silver Subscribed
    Aug 19, 2017
    1,229
    South Carolina
    Andy
    I got a CEL today as well. It’s my second in the past 2 months. I too have a Novitec race exhaust x pipe. Basically just removes the GPF. I also have the Tectronic plug in. As mentioned many times before, if I don’t follow a strict start up procedure, I’ll get the CEL. Both times, I pulled over, turned off the car, got out, locked the doors. Then I unlocked, got in, closed the door, put on my seat belt, pressed the Start button once, let the beeps subside, then pressed and held the start button to crank up the car. The engine icon disappeared after another 10 seconds and never reappeared. The first time it came on I started the car a little rushed and with my door open. Five minutes later the engine icon came on along with the Engine Control System Failure/Return to Dealer message. I really think it’s just the start procedure. No other issues and love the sound.
    Chizz likes this.
  9. F8Guy
    F8Guy Rookie
    Aug 19, 2021
    39
    Carlsbad
    Justin
    AD211 likes this.
  10. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    New Jersey
  11. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    It had to be towed? You couldn’t drive the car? My. Car I can drive as if there were no issues just the cel.
  12. F8Guy
    F8Guy Rookie
    Aug 19, 2021
    39
    Carlsbad
    Justin
    The car would not run, it would start and then quickly die to prevent damage, etc. Had Ferrari tow it to the dealership.
  13. harrish1985
    452
    Miami, FL
    Pm
    pm me
  14. BillHartman67
    BillHartman67 Karting
    Sep 25, 2021
    247
    Montvale, NJ
    Bill Hartman
    Where in NJ? I am in NNJ (Wide World)
  15. Hunter911
    Hunter911 Karting
    Mar 8, 2012
    200
    Toronto, Canada
    "pressed the Start button once, let the beeps subside, then pressed and held the start button to crank up the car"
    - I was told when I picked up my car the first day I always must start the car like this. I've never even tried an immediate push to start.
  16. Hunter911
    Hunter911 Karting
    Mar 8, 2012
    200
    Toronto, Canada
    Is your car a 2021 or 2022?
  17. AD211
    AD211 Formula 3
    Aug 19, 2017
    1,229
    South Carolina
    Andy
  18. AD211
    AD211 Formula 3
    Aug 19, 2017
    1,229
    South Carolina
    Andy
    Yep, it’s not even necessarily an immediate one press to try and start it that fails, it’s doing the press to start (second press) too quickly after the first press. First press just turns on the systems. Gotta have them initialize, beep, etc, then press and hold to start. For me, I guess I rush the second button press sometimes which sets off the gremlins. Who knows.
  19. StevenF8
    StevenF8 Karting
    Feb 11, 2021
    174
    Steven
    Long branch
