Check Engine light 1/4 | FerrariChat
Discussion in '348/355' started by Rmassaroni, May 25, 2020.
  1. Rmassaroni
    Rmassaroni Rookie
    Oct 31, 2019
    1
    Hanover PA
    bob massaroni
    Anyone know what the Check Engine 1/4 Warning means on a 348? My car was running loud for some reason yesterday and the light came on after a short drive....mysteriously, it did not come on after I let it sit for an hour and returned home with it, and it did not run loud either. Any help is appreciated.
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,427
    Ian Riddell
    Not sure what you mean by running loud. Were the fans running? Was it idling faster than usual?
    Check Engine 1/4 means you have a problem with the right bank of your engine (cylinders 1~4). Check engine lights are produced by dozens of different things. We really need more information.
    What year is your 348? Was the car serviced recently? Did you disconnect the battery recently or do you leave it on a trickle charger?
  3. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Go ahead and pull the ecu code and tell us what the code is.:cool:
    But... The post sounds like a troll. Kind of like "my rpms were redlining with no gas pedal applied and throttle bodies were closed, please help".
    Qavion likes this.
