Check Engine light 5-8 | FerrariChat
Discussion in '348/355' started by vonzsolnay, Jul 7, 2016.
  1. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Hey all, my check engine light 5-8 came on, on my 95 355. It then went off, came on, and is now off. Any ideas what this could be?? Thanks so much.
  2. maxvdh
    maxvdh Karting
    61
    MA
    Max von der Heydt
    Time to check your trouble codes by pressing the button next to the (US) driver side ECU and waiting for the CEL to flash a code. That should point you in the right direction. The codes should be stored even though the light is off.
  3. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Thanks so much. Where do i find the ecu?
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    No always - just had the same issue this week and no codes. A good friend experienced this in his 95 and suggested it's likely and O2 sensor. At $50.00, pretty easy test and I have one on hand so will try myself this week.
    Oh, and if you don't already know, when pulling codes you will get an 1121 (PRM sensor) as the motor is not running so no RPM is being sensed.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #5 Dave rocks, Jul 7, 2016
  6. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    If you find a code I bet it's a 1114, 1211, or 1212. If so, my experience indicates most like cause is an old O2 sensor. But with OBD I if it senses a problem it turns on the CEL. If the does not reoccur within a certain time it turns it off. Depending on how long the CEL was lit it may or may not set the code. But, if the CEL goes off it means the error resolved itself. I don't usually recommend replacing parts w/o proper diagnoses but at $60 at Rock Auto, replacing the O2 sensor is a cheap diagnostic tool if you have one of the above codes.
    1212 and 1211 can also mean a problem with the signal from the MAF, i.e. clean contacts at connector, or a vacuum or exhaust leak.
  7. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Thanks so much everyone!!!!!!
  8. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Please report back what you find.
  9. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    The code i got was 1211. Lambda regulator?
  10. maxvdh
    maxvdh Karting
    61
    MA
    Max von der Heydt
    As said before, you most likely have a failed o2 sensor. First thing I'd do is switch it with the right hand o2 sensor and go for a drive. See if the CEL switches to the 1-4 side. If it does, replace that sensor. If not, start checking through other things like wiring and MAF sensors.
  11. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Thank you!! Is that easy to do? Im just learning all the ins and outs. Sorry for all the stupid questions. Thanks again.
  12. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    #12 johnk..., Jul 10, 2016
    If you live in the USA I would not switch it. For $60 from Rock Auto, I'd just put in a new one and see how it goes. Worth the $60 not to have to mess with the other side.
    To change you have to removed the engine bay side shield, remove 3 nut that hold the clips that hold the wire in place, unplug the connector, then get to the sensor with can be a real pain, especially if you don't have one of these.
  13. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Very straight forward job. As John said , get a new one rather than swapping them.
    The wrench John showed makes it easier but may not be necessary. Make sure you put anti seize on the new threads and hopefully the guy before you used it on the old one.
    I had one that was "welded" to the cat on account of no anti sieze. No fun even with the cat removed and in a vise.
  14. ClydeM
    ClydeM F1 World Champ
    12,059
    Wayne, NJ
    Clyde E. McMurdy
    As mentioned, you have a diagnostic code readily available...pull it & read it. why guess?
    My lit LED ('95 spyder) was due to the diverter valve being tied open.
    +1. No swapping sensors or ECUs or anything. If the code points to the sensor, just replace it. If you want, there is a test you can do on the sensor. It's in a thread here somewhere. Put an ohm meter on it & heat it with a propane torch and check the ohms. Then chuck it 'cause you've already put a new one on. BTW: mine tested fine this way and I still chucked it as I replaced it for < $30
  15. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Thanks so much. Will order and try!!
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    New Bosch sensors come primed with anti seize.
  17. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Now here is one of several reasons why an F355 Challenge is so much fun. My 1995 always throws check engine lights for both banks. Prior to its major service two years ago, it was the Check Engine 5-8 light that would come on when the car was idling or moving slowly. It went off when I picked up speed, The light for the 1-4 bank came on occasionally and behaved like the 5-8 bank light. After the major service, both lights come on within five seconds of each other and go off the same way when I pick up speed.
    I guess my engine is properly balanced. :D
  18. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Where do i find in the rock auto site? Thanks so much.
  19. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
  20. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I've had a few seized ones as well, Bob. So much for the effectiveness of "factory applied" anti-seize....
  21. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Where do i find the o2 censor? Im looking everywhere. Lol.
  22. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
  23. vonzsolnay
    vonzsolnay Karting
    Jun 2, 2015
    88
    New York
    Frank
    Thanks Johnk, i found on the site, but cant find the actual censor in the car. Lol
  24. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    On the front end of the catalytic converter.
  25. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    #25 johnk..., Jul 11, 2016
