Check engine light came on | FerrariChat
Discussion in '348/355' started by buddyg, Mar 4, 2017.
  1. buddyg
    buddyg F1 Veteran Rossa Subscribed
    Sep 20, 2004
    6,376
    Naples, FL
    Buddy
    So my car has been sitting in the garage with the battery switch off. I turned it on, started the car let it warm up a bit and then started driving up and down my private street. (Too much salt on the main roads). Got it nice and warmed up and then started to giving some RPM's and wind it out a bit. Got a check engine light. Turned the car off and back on and it's still there.
    Any thoughts? What inexpensive OBD II scan tool will work on my car it's a 1997. Would like to clear the code and see if it comes back.
  2. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Buddy - pickup a scanner and read the code(s) first. OBDII is very good at providing useful codes.
  3. buddyg
    Sep 20, 2004
    6,376
    Naples, FL
    Buddy
    What scanner do you recommend?
  4. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
  5. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,041
    Indio Ca/ Alberta
    Grant
    They will all work more expensive ones oftain have feature that wont work for our cars anyway.
    I have a couple and the 50 dollar range gives you what you need usually.
    My guess is an o2 sensors is bad, its quite common bu pick one up and try it.
    What kind of exhaust, muffler, cats are you running??
  6. buddyg
    Sep 20, 2004
    6,376
    Naples, FL
    Buddy
    All stock, last time I had it out it was fine and the car was running fine after the light came on. Hoping maybe it just resets and goes away.
  7. Dave rocks
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Don't bet on it :)
  8. taz355
    Feb 18, 2008
    6,041
    Indio Ca/ Alberta
    Grant
    That has never happened for me!!
    Tell us why its throwing the code and then just fix it.
  9. 308 GTB
    308 GTB F1 World Champ Rossa Subscribed
    Feb 7, 2002
    11,758
    New Jersey
    Barry Wolinsky
    Now here's one of several reasons why an F355 Challenge is so much fun. My 1995 always throws check engine lights for both banks. Prior to its major service three years ago, it was the Check Engine 5-8 light that would come on when the car was idling or moving slowly. It went off when I picked up speed. The light for the 1-4 bank came on occasionally and behaved like the 5-8 bank light. After the major service, both lights come on within five seconds of each other and go off the same way when I pick up speed.
    I guess my engine is properly balanced now. :D
  10. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    So have you bothered to check the codes? Sounds like possible vacuum leaks.
  11. 308 GTB
    Feb 7, 2002
    11,758
    New Jersey
    Barry Wolinsky
    No, we haven't bothered doing that. I was told to ignore the lights as it has something to do with the way the ECUs were flashed when the car was tuned. My car retains its catalytic converters and has its (valve-less) Challenge exhaust. The car idles rich and leans out with engine speed.
    Check Engine lights behaving this way is common amongst Challenge cars.
    Here are the dyno graphs with air/fuel mixtures...
  12. taz355
    Feb 18, 2008
    6,041
    Indio Ca/ Alberta
    Grant
    So the ecu in buddys car is not stock then??
  13. johnk...
    Jun 11, 2004
    11,272
    CT
    John Kreskovsky
    That is certainly rich at idle. Do you know why they tune it that way?
    Different car.
  14. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
