Check Engine light on 1998 355 F1Spider | FerrariChat
Discussion in '348/355' started by Dennis Wright, Dec 18, 2021.
  1. Dennis Wright
    Dennis Wright Rookie
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    I just purchased a 1998 355 F1 Spider. Engine out service done by Lance Hedrick first of December. The car is gorgeous! Question, it appears my 'check engine' light doesn't come on when turning the key. What is the check engine light symbol and where is it located?
    It looks like it may be an 'engine symbol', orange, located at the bottom of the dash? Any thoughts on why it doesn't come on? The only orange indicator that comes on and goes off is a little car symbol with hood up and says 'auto'.....thanks for any help
    Dennis
  2. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,317
    SoCal
    Someone may have purposely removed the light bulb. Instant Fail on a Cali smog check.
    Hook up your OBDII scanner and see if your throwing a CEL.
    Steve Magnusson likes this.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,602
    San Carlos, CA
    Mitchell Le
    If you read the OBD2 code, you will see if there is a code for missing CEL light. I bet you have some codes ...
  4. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Thanks, I had it at my mechanic yesterday and the OBD2 code reader had a bunch of codes!
    He cleared them and said to drive it a bit and bring it back on Monday.
    I'll be back to him on Monday and check for the CEL code for missing light.
    Same here in Texas, instant fail if the 'check engine' light doesn't come on and go off...and I can't get license tags and the car registered without this inspection.
    Qavion likes this.
  5. Mike Morrissey
    Mike Morrissey Formula 3
    1,143
    Denver, Colorado
    Mike Morrissey
    Dennis Wright likes this.
  6. Qavion
    Qavion F1 World Champ
    14,376
    Ian Riddell
    The F1 car should look like this:
    Newbies often get caught out by the "hood open" symbol. It's actually a "gear selector on console" ;)
  7. Tarek307
    Tarek307 Formula 3
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    someone definitely removed the bulb - easy fix, but of course you will have to cure the main issue which is why does it come on..you should buy a wifi OBD reader and hook it up so you know what faults you have
  8. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
  9. Ferrari Fanatic
    Apr 2, 2003
    1,317
    SoCal
    Congrats on your new baby ! If you start to throw codes even “pending” and the bulb was removed, then safe to assume someone was chasing a gremlin.
    The pain point comes when you reset the OBDII and throw codes before the system is ready for testing. Compounded with the fact that a drive cycle can take hundreds of miles.
    Well I am just sharing info as a previously Licensed California Smog Technician.
    Keep us posted and I am sure you will work through it.
  10. yelcab
    Nov 29, 2001
    13,602
    San Carlos, CA
    Mitchell Le
    A proper drive cycle takes 30-45 minutes.
  11. Ferrari Fanatic
    Apr 2, 2003
    1,317
    SoCal
    Only 2 non-continues monitors max, to be in a Not Ready state to pass the test.
    Getting the car ready to test without throwing a code ( on a car that already throws codes ) not such an easy task.
    If a Tech feels it’s a lucrative endeavor, more power to them. We need more of them.
  12. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Thanks everyone , I’ll get my license plates...”where there’s a will, there’s a way”
    26street likes this.
  13. Ferrari Fanatic
    Apr 2, 2003
    1,317
    SoCal
    Agreed. Enjoy in good health !
  14. 26street
    26street Formula Junior
    Jan 30, 2021
    471
    Westchester New York
    Mark k
    Dennis not sure where you are located but does your state give you a temporary inspection when to register the car ???
    I’m in NYS they do but only good for a week or so
  15. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    I’m in Texas, don’t think I can get a temporary inspection, ....I have at least one ‘resource’ to get that inspection without having it inspected, if you get my drift ;)
    Pepsi10 likes this.
  16. 26street
    Jan 30, 2021
    471
    Mark k
  17. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Ferrari has been inspected! :) ...now to register and title it!
    Pepsi10 likes this.
  18. 26street
    Jan 30, 2021
    471
    Mark k
  19. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Hey guys, next question....the soft top has been converted from automatic to manual operation.
    Have put the top down a couple of times, windows would go up and down....now, with the top down, neither the passenger or driver windows will operate.
    Can anyone suggest what I need to do to get the power windows to operate?
  20. Qavion
    14,376
    Ian Riddell
  21. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    The power seats work, but, the power windows don't. From looking, if that switch was still plugged in, wouldn't the power seats not work also?
  22. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    The microswitch referred to above, is still plugged in
  23. Qavion
    14,376
    Ian Riddell
    Then disconnect it ;) This will simulate the roof being fully down and should reactivate the windows.
  24. Qavion
    14,376
    Ian Riddell
    #24 Qavion, Jan 1, 2022
    (EDIT): This switch only inputs into the window ECU.
    There are inputs into the Roof ECU from the switches in the primary rams which may reactivate the seats.
    Wiring diagram here:
    https://www.dropbox.com/t/wZtgXvV6Do9ABZpt
    Hydraulic diagram here showing some of the switches:
    https://www.dropbox.com/t/19MBxySFYc1iS6E9
  25. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    The top is up, but the power windows still don't work? Microswitch is till plugged in
