Check Engine light on 1998 355 F1Spider | Page 3 | FerrariChat
Discussion in '348/355' started by Dennis Wright, Dec 18, 2021.
  1. Dennis Wright
    Dennis Wright Rookie
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Qavion likes this.
  2. Qavion
    Qavion F1 World Champ
    14,600
    Ian Riddell
    I see Eurospares has a used arm for U$575.
    P/N 63690600
    I wonder why it broke?
    Dennis Wright likes this.
  3. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Because I was toooo rough with it!
    I wrapped heavy gauge wire around the nut, fit the broken part back to the claw, and tightened the wire around the claw where the broken piece fits, top back up and the claw worked perfectly holding the top in place!...AND, lo and behold, the power windows are working again! Yay! :)
    Qavion likes this.
  4. Qavion
    14,600
    Ian Riddell
    How strange. There seems to be something I've overlooked here. If the roof is not latched, the windows drop. The only way of getting the windows to move again is having the roof fully down (as sensed by the slider switch) or by relatching the roof.
    What was stopping the windows moving with the roof fully down? Did you refit the slider switch (near the passenger door)?
    Anyway, that sounds like very good news.
  5. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    The roof has been converted from auto to manual just a few weeks ago, right before I purchased it....the windows don’t move by themselves at all, whether putting the top up or down...I haven’t touched anything other than “engineering” that broken arm to the claw! ;) ....I’m a happy camper at the moment :)
  6. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Ferrari’s are magic!!!! lol
  7. Qavion
    14,600
    Ian Riddell
    So even now they don't move by themselves. This tells me that the mechanics may have unplugged something related to the windows during the converstion. Maybe they simply disconnected one of the plugs on the Window ECU. With the "B" plug removed, the Window ECU probably reverts to being a GTB or GTS Window ECU. There is no input from the windshield switch, the slider switch or the windows 2 inches down switches (in the doors) with the B plug removed.
    Note that the 348 Spider, even though it doesn't have roof hydraulic control, it still has automatic window control so you don't break the window glass when putting the roof down/up.
  8. Qavion
    14,600
    Ian Riddell
    Ugh... And the obvious flaw in that theory is that the windshield switch also goes through the "B" plug. Your windows started working after you fixed the hook, so the windshield microswitch must still be working.
    I still have no idea why your windows are not operating automatically.
  9. SPEED WORKS
    SPEED WORKS Rookie
    Apr 25, 2007
    33
    Orlando, FL
    Bill Fulkrod
    Usually when they change out the exhaust it throws the check engine light, so they delete the check engine to put the cat bypass pipes in. Does it have factory exhaust?
  10. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    It has tubi exhaust
  11. Pepsi10
    Pepsi10 Formula Junior
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Hi. About your windows that do not work when your top was down. Your thread has now changed topics to your broken piece on the top. But, about your windows that do not work when the top is down. This summer I had that problem, on my spider, windows worked with the top up. But would not work with the top down. So I basically had to decide, before putting the top down, where I wanted the windows. Anyway, I did exactly as described in the thread I have pasted below. And everything is working perfectly now.
    Meaning I ordered the same switch, and replaced the broken switch myself. I understand you are not a handy person, you said that. 1.Even so, I think you could do this repair. If you decide to do it yourself, I have a suggestion about the soldering, which is in tight quarters.* 2. If you do not do it, you will have the switch required for another mechanic to do it. With the directions in the thread, it is very easy.
    https://www.ferrarichat.com/forum/threads/how-to-repair-f355-spider-top-sensor-for-power-windows.522719/
    *I was having a problem doing the soldering, and having my heat shrink tubing getting too hot during the soldering. My one suggestion to the thread I linked, would be to buy these new connectors (on amazon, listing below), where you slide the connector on one wire, create a mechanical connection between your two wires by bending them together, and then slide the Shrink butt connector solder sleeve over the stripped wires, and then heat shrink the package, and everything is good. They basically are solder and heat shrink tubing together in one tube.
    Kuject 120PCS Solder Seal Wire Connectors, Self-Solder Heat Shrink Butt Connector Solder Sleeve Waterproof Insulated Electrical Butt Splice Wire Terminals for Marine Automotive Boat Truck Wire Joint
  12. Qavion
    14,600
    Ian Riddell
    Thanks for the reminder, Mike, but it was proved that the switch was not at fault. Normally, the switch goes open circuit when the ram extends (fully down). This was simulated by disconnecting the switch (and the windows still did not work)
    Also, the roof has been disabled, so the primary rams may not even be installed or may be hanging loose, so there will be nothing to activate the switch.
    At 2:25 you can see the switch disconnected.
    Unfortunately, it's not clear what has been done to the wiring during Dennis' conversion.
    26street and Pepsi10 like this.
  13. Dennis Wright
    Feb 19, 2020
    49
    Ft Worth, TX
    Dennis M Wright
    Thanks for all the information guys! Much appreciated...I’ve ordered the broken rod from eurospares, may be a month to get it...
    windows work with the top up, and will stay that way for the time being...it’s winter here in Texas :)
    Qavion likes this.
