check engine light on 355 | FerrariChat
Discussion in 'Technical Q&A' started by ROCKY1634, Apr 3, 2004.
  1. ROCKY1634
    ROCKY1634 Karting
    Nov 12, 2003
    80
    I am having problems with the check engine light on my 1997 355. my code reader gives me the following codes; P1448, P1449, P0422 and P0432. the P0422 and P0432 are generic codes relating to main catalyst efficiency below threshold on bank 1 & 2. the other two are ferrari specific codes and I don't know what they are. I suspect that my problems are O2 sensor related but b-4 I replace all 4 sensors I would see what the panel thinks. by the way the car has 29000 miles on it. any help will be appreciated, thanks
  2. delaney
    delaney Formula Junior
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    I've just got the P1448 ... Catalyst flap by pass circuit ..
    Where did you get your definition of the cats acting below efficiency ... I've just had two new cats (under warranty) ... do you know anything about P1128 ... Upstream HO2S sensor swapped?
    Looks like we have something in common!
    By the way ..main dealer said they did not have the P1448 code in their books.
    Pete
  3. Diablo
    Diablo Formula Junior
    Jan 6, 2004
    443
    In front of the comp
    Just to let you guys know, codes that come from the Ferrari using a reader that is not SD1 or 2 will really be junk to dia with. The readers clear them pretty well though.
    As for the by-pass, check all 3 of your slow down ECU's. Most likely one or all 3 have a crack that has developed around the outside edge where the plastic meets the black inner gell stuff. Ferrari has updated these ECu's to a green material to stop the cracking.
    Good Luck to you.
