"Check Engine" light on 360Modena stays on | FerrariChat
Discussion in 'Technical Q&A' started by Tomf-1, May 20, 2004.
  1. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Leawood KS/ South FL
    Thomas
    for some unknown reasons, the "check engine" light on my 360M came on and stayed on....everything else works perfectly.
    1- is this something serious (again, the car runs perfectly and all readings are normal on the dashboard)?
    2- what could be the causes?
    car just had its major service (out of town...) and i will have it check out but would like to solicit your opinions, 360M owners/mechanics/360 gurus...anyone...anyone?
    tom,
  2. 911Fan
    911Fan Formula 3
    Apr 15, 2004
    1,294
    Southern California
    Make sure the fuel filler cap is tight. Really tight.
  3. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Thomas
    Checked. Not it!!!
    Good thinking, though. Thank you...
  4. Diablo
    Diablo Formula Junior
    It could be anything.
    You will have to have it checked out by a tech. Sorry.
  5. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    Sounds like a faulty sensor or relay. The tech. will hopefully locate it with the computer. What yr. is your 360 and what service was done?
  6. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Thomas
    Hello Drew-- She is a 99 and 15K service done.
  7. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    Beautiful and a 6sp....Perfect!
  8. raygr
    raygr Karting
    Nov 1, 2003
    130
    Seattle Area
    Ray
    When the dealer hooks up their diagnostic unit, they will get a code out of it that says what the problem is.
    I had the CEL come on twice on my 02 360. First time the dealer said they needed to upgrade the software - apparently a glitch in the old software could cause the light. The 2nd time, they said it was caused by an erroneous reading from the throttle sensor. But, it was never reproduced, so they just cleared the CEL and it hasn't happened since. I got the impression that spurious CEL on 360's are not uncommon.
  9. Tomf-1
    Tomf-1 F1 Rookie
    Jan 17, 2004
    4,528
    Thomas
    Thanks Ray for the reassurances....It makes me feel better
