Check engine light on and car lost power on 360 | FerrariChat
Discussion in 'Technical Q&A' started by Mon, Mar 7, 2004.
  1. Mon
    Mon Karting
    Feb 15, 2004
    97
    The check engine light came up while the car was driving, suddenly the car lost power and having ticking noise from engine. I called service department they told me to twist the knob in the front hood to off position, shut the car off and twist it back to on position again. Now the engine light is gone.
    What is that knob for? and Is my car is OK?
    Thanks!
  2. XSSSIVE
    XSSSIVE Formula Junior
    Dec 7, 2003
    705
    Reno & Lake Tahoe
    Mike S.
    I just had the same problem with my 360. The nob disconnects the battery. In essance, you are turning the computer off hoping the problem was only temporary. When the computer reboots the error is erased from it's memory.
  3. Bertocchi
    Bertocchi Formula 3
    Jan 28, 2004
    2,348
    Austin, Texas
    David Castelhano
    The check engine lights in all OBD2 cars are primarily related to emmission controls. If your car is running with one side or the other in a "rich" mode it could potentially cause the catalytic converters to be overloaded and overheat. The heat could potentially cause all kinds of problems besides the fact that the government does not want those excess hydrocarbons polluting the air. The ECUs will shut down one bank or the other to prevent such a condition and thus the loss of power. After it cools down and you reset the ECUs by turning off the battery the condition could correct itself. Do you always by the best gasoline possible from stations with new tanks in the ground?
  4. Mon
    Mon Karting
    Feb 15, 2004
    97
    Brought the car to service, they found out that I was driving to fast after I started the car.....they said I shoulda warmed it up first before start punching. They cleared the memory lock for my car too.
  5. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    Hey Bertoochi.........you're good!
  6. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Aside from using good fuel and not letting the tank get low between drives, you should be holding off until your oil temperature guage begins to move before you punch the pedal. For my 360 that amounts to around six miles or so of non-highway driving. No problems so far.
  7. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    Ken, glad to hear your taking as good a care of her as I did. Hope you are enjoying every drive.
  8. ZINGARA 250GTL
    Jun 21, 2002
    17,499
    PA
    Ken
    You betcha, Morrie. Would like to use the same wax as you used. E-mail me if you have time. Hope to see you in Wilmington.
