Check Engine Light on F355 | FerrariChat
Discussion in 'Technical Q&A' started by mpodgor, Feb 19, 2006.
  1. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    I have a 1999 F355 with the Motronic 5.2 ststem. The check engine light is on. Car has 13K on it. Took it to an independant shop. The sd-1 shows 3 failures.
    #1 "worn catalytic converter present
    #2 "Front oxygen Sensor heating" present
    #3 " Secondary air Pump" present
    I'm having a hard time believing all 3 items failed. I would like to replace that front 02 sensor but can't find a source that sells them for a 199 355. Is this a hard to get part? Any eqiuvalent 02 part numbers?
    Also I want to get an OBDII scanner. Can someone recomend a specific model. I don't have a laptop. Last thing. If it boils down to the cat. I'm unclear as to what the warranty is. I hear 7 or 8. I live in Ca. Bought the car last July.
    Appreciate any help with this.
    Yellow 355 Mike
  2. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,073
    Pocono Sportscar
    Jim McGee
    check the fuse for the air pump located in the passenger foot area fuse box. You will most likely find it blown. This will possibly give you the indications that you have there.
    If it is blown, You may have a bad pump. I have found some that the fan impellers in the pump break and jam up the pump motor causing the fuse to blow.
    at least a first spot to look.
    best regards and let me know what you find.
    Jim
  3. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,035
    Summerfield, NC
    Tom Jones
    There are cat problems with 355's. The cats are covered under the 8/80 warranty. We have had several sets replaced at the dealer. You may want to take a chance and let an authorized dealer look at it. Jim is right about the fuse. I have replaced a bunch of the fuses. I don't understand why they use such a low amp fuse on this. Other manufactures use a 40 amp maxi fuse. I usually replace the 15 with a 20 amp fuse and have not seen one come back blown yet.
  4. Rifledriver
    37,288
    Ca. cats are 7-70 from date of original sale. Do what Jim said, put a fuse in the air pump. Also at that independant shop with the SD1 you should be able to watch downstream O2 to tell if the cat really is worn.
  5. Rifledriver
    37,288
    Ferrari told us to replace them with a 30. But Jim is right, in my experience most of the air pumps that blow fuses are going south. Either blades or bad bearings.
