Check Engine Light? | FerrariChat
Check Engine Light?
Discussion in '360/430' started by Ingpr, Sep 27, 2009.
  1. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    #1 Ingpr, Sep 27, 2009
    Hi guys!
    After I sent my car for Timing belts replacement,
    Valve Cover Gasket Replacement Both LH & RH,
    Front oil seal for cam shaft rerplacement,
    Fuel supply lines Rh & LH replacement,
    Spark Plugs replace,
    Complete Clutch Kit Replacement,
    RH & LH Radiator Fan Replacement,
    Clutch Sensor Support Flange,
    Clutch Thrust Bearing Replacement,
    Complete Gearbox Bell Housing Wash and
    Install a maxspeed exhaust.
    I test the car for two hours and the Check Engine Light comes up! Any Idea what could be the problem?
    Thanks!
  2. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    with all that work done, and the money you spent on such an extensive service, the car should be picked up by flatbed and returned to the shop asap. just my opinion.
  3. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    where did you "sent it" ?
  4. Oengus
    Oengus F1 World Champ
    Thants funny!
  5. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    The last item in your list caught my eye. Did you just do a bolt-on exhaust of did you do high-flow cats and an exhaust? CEL could be related to the new exhaust system...
  6. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    Thanks for looking!
    It was a bolt on exhaust, the cats are ffrom factory
  7. trialman1
    trialman1 Karting
    Oct 18, 2008
    72
    new york
    steven
    when it happened to my 360 it was due to a vapor lock caused by the gas cap not being put on properly. It was a simple computer reset to fix the problem. Did you get gas recently? or it could be due to the new exhaust
  8. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,454
    stop by an auto zone if theres one in ur area and have them pull the codes from an obd 2 reader
  9. TALON30
    TALON30 Karting
    Jan 8, 2010
    171
    i had a bad gas cap and engine light came on.. how do you reset the computer to get rid of the light?
  10. blkdiablo33
    Jul 12, 2004
    4,454
    if you dont have a obd2 scanner just disconnect battery switch for a few minutes.than reconnect.
