CHECK ENGINE LIGHTS CLEAR | FerrariChat
Discussion in '456/550/575' started by jaticker, Aug 23, 2016.
  1. jaticker
    jaticker Formula Junior
    Oct 27, 2007
    251
    tampa
    John Annis
    Got stuck in a long traffic jam. Temps were a little over normal. Now, Both CHECK ENGINE LIGHTS came on. The center of the dash and the smaller yellow check light, both on. Car ran fine and still does. I check the usual, gas cap etc. Turned off battery switch, did remove battery cable.
    I've searched the forum on how to clear the lights, no luck.
  2. ///Mink
    ///Mink Formula Junior
    820
    Fair Oaks, CA
    Tom Mink
    You need an OBD-II code reader to read/clear them. Plenty of them available for under $50.
  3. jaticker
    Oct 27, 2007
    251
    tampa
    John Annis
    All fixed. The OBD cleared the code.
