check engine with no comunication | FerrariChat
Discussion in '348/355' started by JFLANAGAN, Apr 13, 2011.
  1. JFLANAGAN
    JFLANAGAN Rookie
    Apr 13, 2011
    2
    pennsylvania
    Jim Flanagan
    Well here we go I have a 1998 F355 with check engine that is stuck on bought that way this car will not comunicate with any scan tool including Launch and AutoBoss. Now do not know what fuses power what and it seems the ALDL is hooked up to the ECM any help would be appreciated on this matter
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #2 2NA, Apr 13, 2011
    There is likely a missing ground terminal in your OBDII connector that won't let your scan tool connect. If that's it it's a simple fix.
    Here's the service bulletin about it.
  3. Barnone 308
    Barnone 308 Formula Junior
    Mar 22, 2004
    432
    canada
    Had the same issue when my 355 arrived, Simple fix I used my Innova 3100 scan tool cancelled all codes and it came off.
  4. JSBMD
    JSBMD Formula Junior
    Mar 17, 2007
    453
    The OC
    Also, at least in my '98 355, if you don't first disable the alarm, the scan tool will not read the OBD II port. Seems the alarm (which auto sets itself) disconnects the ability for the scanner to communicate with the car.
  5. JFLANAGAN
    JFLANAGAN Rookie
    Apr 13, 2011
    2
    pennsylvania
    Jim Flanagan
    Found a black connector unplugged at ECM pluged and found 25 codes cleared codes ran car for a day or so light came on have 5 codes p0151 02 sensor B2S1, p0157 O2 sensor B2S2 p0131 O2 Sensor B1S1, I know what they are however thier are 2 codes that I have know idea P1117 and P1121 any help would be greatful.
  6. f355spider
    f355spider F1 World Champ
    18,055
    #6 f355spider, May 5, 2011
    P1117 is O2 sensor heater circuit bank one, sensor 2 (passenger side, post cat O2 sensor needs to be replaced)
    P1121 is same for drivers side.
    Sounds like you need to pick up two new Bosch pre and post catalyst O2 sensors. The Bosch part number is 13820 for post cat. I see them for $75.41 each on Amazon.com ;)
    The correct pre cat O2 sensor is Bosch 13819. Both part numbers I listed are correct for 1996 to 1999 F355 with 5.2 Motronic. Do not trust the Bosch online look ups, they are wrong, and if you use the O2 sensors they list you WILL get "check engine" lights.
  7. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    Funny....I paid $47 for TWO of these SAME Sensors on Amazon 2 days ago...:rolleyes:
  8. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    I have an emissions CEL too from last year...now when I plug in the OBDII similar to posted above it doesn't read any codes, but the light is still on.
