Check low side a/c pressure | FerrariChat
Discussion in '308/328' started by armando_sf, Aug 28, 2021.
  1. armando_sf
    armando_sf Rookie
    Jun 9, 2008
    35
    San Francisco
    Armando Levy
    All,
    I am trying to check the low side a/c pressure. I used two sets of guages and am not getting a reading. I am wondering if the square fittings at the end of the valves need to be opened to have the valves open. See attached picture.
    —a
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,954
    Central NJ
    Dominick
    That looks.like a backseat valve
    When stem is all the out hose adapter is closed
    The the stem is mid way about half a turn or so all three outlets are "connected"
    When all the way in you shut off the lines so you can disconnect without losing refrigerant
    Clockwise turn to move stem in ..just do a half a turn
    Be careful not to seat in and run compressor
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,812
    Cerritos, CA.
    Did you remove the Schrader valve from the original fittings before you installed the retrofit 134A fittings that also has the Schrader valve?
  4. armando_sf
    armando_sf Rookie
    Jun 9, 2008
    35
    San Francisco
    Armando Levy
    @flash32 – thanks for the tip I’ll try turning in to see if I get access. @miketuason — I assume the retrofit came with new valves. The shop did that and the system did work for a time.
    —a
    miketuason likes this.
  5. miketuason
    Feb 24, 2006
    15,812
    Cerritos, CA.
    #5 miketuason, Aug 29, 2021
    Yes, if you can, check it, it is important although even with the schrader valve is still on the original fittings, it will still work but not very efficient and it’s wrong.
    photo shows the valve on both, you only need one, the one from the 134A fittings.
