Checked the oil level when it was cold | FerrariChat
Discussion in '360/430' started by espvh, Aug 9, 2016.
  1. espvh
    espvh Formula Junior
    Nov 11, 2005
    553
    NEW YORK!
    Well, after multiple times of trying to check the oil level when my 360 was at full operating temperature, without much success, I finally was able to see the level at full, without any foam, when I checked it when it was running, but from a cold start. I tried the way that was recommended, but to no avail. I even tried the method of shutting it off for a few minutes, when it was at full operating temp, and restarting it, and checking it, again, to no avail. In all occasions, there was foam all the way up the dip stick. This time I started it from cold, ran it for a few minutes and checked the oil and it was perfect, as it should be because I just had it recently changed. I'm not recommending this method, you should try to check it as recommended, but for me personally, it seems to work the best. For what it's worth I'm running Spectro full synthetic oil.
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Oil level should be checked with the engine hot. If your current oil foams that badly, it's time for a different oil. The factory procedures work just fine. Deviating from them, particularly determining the oil level with the engine not a operating temps ensures an overfilled condition.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It makes a BIG difference to check the level cold versus warmed up. If it appears full when cold, you are overfilled.
  4. espvh
    Nov 11, 2005
    553
    NEW YORK!
    My current oil foams as well my previous oil, maybe will try a different brand next time, even though I was told that Spectro was one of the best and shouldn't foam, it does. Trust me, I would love to do it the way the factory recommends, but at this point, I think it's my only alternative. Plus, isn't the engine fully lubed after a few minutes?
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I use Pennzoil Platinum Euro SAE 5W-40 in my 355's and have no issue with foaming. As the 355 is a dry sump, I check oil (hot) at idle.
  6. nietoale1
    nietoale1 Karting
    Dec 28, 2012
    226
    NJ
    Alex Nieto
    Switch to Redline oil, I switched from the Shell...night and day.
    You can check the oil level after a spirited long drive...no foam at all.
  7. espvh
    Nov 11, 2005
    553
    NEW YORK!
    So I'm willing to take out a half a quart and see if there is a difference, (foaming), is there a way to remove some oil without removing the drain plug?
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I don't believe Tim is suggesting the foaming has anything to do with the amount of oil. He is just saying that you need to check it when hot and not cold.
  9. 53ford
    53ford Karting
    Nov 13, 2009
    112
    Use a turkey baster to draw the oil out.
  10. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    +1. There is a lot of variance between checking the oil cold and after it expands as it gets up to full temperature. Dry sump motors hold a lot of oil so the variance can be measured in quarts. You don't want the car overfilled as it can lead to other issues!!
    Get a siphon and hose, start up the car cold and start pulling out some oil as the motor warms up and the oil thins a little- this only takes a minute or two (if you do it when the oil is too hot it will be more challenging, standing between the hot exhausts, pulling hot oil and trying not to spill any on the motor/engine compartment).
    When you want to check the oil, loosen the oil cap so it's not super tight, drive the car up to full operating temperature, park the car on a level surface and check the level at idle. Use a rag as the oil dipstick and knob itself get very hot.
    Aim to get the oil level somewhere between min and max at fully warmed up idle vs at the max line.
    My guess is you can pull out 1-2 quarts of oil from your car, and then measure- if you are at the min line, add say 1/2 quart and see where that leads you. Even at min there is a lot of oil in the car so it wont cause an issue (of course I wouldn't recommend being at min or below then going on a banked race track or anything :) )
    The whole process is a pain in the butt I know (especially since you car sounds like it is overfilled), but it is what it is. My aircooled 911s (also dry sump motors) were much easier to maintain- there is even an oil level gauge in the aircooled 911s that was pretty accurate to what was on the dipstick. With a fully warmed up 911 you can do an oil check at a stop light after the car was at idle for about 10 seconds by simply looking at the gauge!! I wish the dry sump ferraris had this gauge...
  11. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    The problem with foaming is that it makes it difficult to ascertain where the level actually is. I am not familiar with Spectro; good, bad or indifferent.
    So, excessive foaming could mean an oil issue of simply that you are way overfull. Personally, I would drain the sump (both drain plugs), cooler lines, etc. and add 10 quarts of either RedLine 5W-40 or Pennzoil Euro. Let the car get warm and then check the oil level per the WSM. The procedure outlined should work just fine. 10 quarts should put you on the low side of the mid-range on the dip stick. Add from there, as needed.
  12. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,692
    Honolulu
    Kevin
    I avoided this oil because I read that it foams but Dave is right. It does not and is recommended by Ferrari. Easy to mail order from Amazon too.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #13 Dave rocks, Aug 9, 2016
  14. Shinigami
    Shinigami Formula Junior
    Aug 2, 2005
    465
    Gland Switzerland
    Heikki
    My question is, since you're meant to check the oil when warm, I find the OIL cap to be really hot to the touch! Do you guys use gloves to screw it off?
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Use gloves or a rag...
  16. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,125
    Calif
    Brett
    Redline 5-40 never an issue. Also, when doing oil changes, measure what comes out, replace and then check HOT. If you can hold the oil cap it is not hot enough!
  17. rugby
    rugby Formula Junior
    Apr 10, 2015
    364
    Atlanta
    I just did some calculations using numbers randomly scrounged on the internet.
    Assuming the numbers are right, if the stick shows full at cold it will be a little more than half a quart high at hot.
  18. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    Penzoil w/ the Ferrari Logo on it, foamed up on me quite a lot.....so, back to Redline...no foam : much easier to read level again.
  19. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    "Full" is between the marks when at operating temperature. It is not necessary or even a good idea to fill to the top mark.
    Remember that it has 10 quarts of oil in it. It's better to be a little bit low than overfilled.
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Exactly. Too full will often lead to blue smoke out the pipes when getting on the car. When I got one of mine it was filled to high and had this problem. Proper oil change with proper fill level resolved it. Good advice, Tim.
  21. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Too full can do more than just blue smoke.
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Inquiring mind would like to know??? I've never overfilled oil so never considered any possible issues.
  23. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Besides making the whole intake system a mess, the MAFs don't like oil.
    Sent from my SM-G930T using Tapatalk
  24. espvh
    Nov 11, 2005
    553
    NEW YORK!
    Thanks all, took out about a quart, level is perfect when hot and no foam! This place is truly a must have resource for Ferrari owners. You guys are all aces in my book!
  25. stevecomp
    stevecomp Formula Junior
    Mar 1, 2013
    743
    South Australia
    Steve
    The MAF's are way forward of the throttle bodies and oil scavaging pipes it must make a lot of plowpast to mist oil on the MAF wire that is facing the air filters.
