checking oil level 355 | FerrariChat
Discussion in '348/355' started by PAUL500, Sep 24, 2013.
  1. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Should this be done with the engine running or switched off?
    Thanks for any help
  2. RWP137
    RWP137 Formula 3
    Apr 29, 2013
    1,613
    AZ
    Rick
    Running or just switched off and Hot. Otherwise you'll give yourself a heart attack...trust me. And make sure you cover your hand (oven mitt). The metal cap gets real hot.
  3. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Exactly, my friend dipped it when cold and panicked and has now overfilled it as a result so its now smoking like a good un. I sort of realised what had happened so now need to drain some oil off for him.
    Thanks for confirming :)
  4. WATSON
    23,933
    WI
    Ferrarichat's search capability is marginal.
    However, in most browsers, you can search a site directly using this syntax:
    Check Oil 355 :ferrarichat
    The results reveal many answers ;)
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    Run the engine long enough for the oil to get full hot--it will take less gas to drive 5 miles down the interstate and back than idling in the garage to get it sufficiently hot.
    Park the car with the engine running, pop the bonnet.
    Now, turn off the motor, get out of the car, open bonnet and unscrew the oil cover.
    Wipe down the first reading, screw the oil cap back on and the back off and read the oil level.
  6. cuneo
    cuneo Formula 3
    2,484
    For some reason my car absolutely has to be running when checking oil... Even 5 seconds or less after shutoff it reads bone dry. Maybe my car is a freak.
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Watson, with all due respect, this is a forum and people are going to ask the same questions over and over, let's just answer them or not. I recall my first post where you dumped on me for not searching, if it bothers you, just don't reply ;-)
    Check the oil while HOT, at idle and be carefull coz the cap is super hot!
  8. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    +1
  9. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Thanks gents, perfect answers, appreciate your help and input :)
  10. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Second question 5w or 10w, the 5w just seems to thin on a higher mileage engine. When I swapped across on another car the difference was amazing, oil consumption dropped considerably.
  11. Mitch Alsup
    Nov 4, 2003
    9,742
    Unless you are starting the car in sub+30dF temperatures (that is below +30dF) the difference between 10W-40 and 5W-40 is negligible.
    It is generally the NOACK number that controls the oil consumption on older engines.
  12. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    ah ok
    on the other car in question I went from a 5w40 to a 10w50 and oil tops ups stopped being required as a result
  13. WATSON
    23,933
    WI
    Whoa. Gave the guy a search option and I get that Dave?
    Ok then.
  14. WATSON
    23,933
    WI
    #15 WATSON, Sep 25, 2013
    From the manual:
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Several respected mechanics here suggest checking oil while under idle, engine running. I do this and it works perfect.
  16. WATSON
    23,933
    WI
    You can do it with the engine running. But that is not what the manual suggests.
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If one wants to race around to the back of the car and have any confidence that the timing is consistent, then that's cool with me but not something I'm going to do.
  18. WATSON
    23,933
    WI
    I just follow the manual...probably the best way given the manual's author. But hey....
    Have done it both ways. Results were the same. I have low foam oil so it really doesn't matter for me anyway.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Except manuals are written when or before products hit the market and therefore lack field data...
  20. WATSON
    23,933
    WI
    I agree. If it mattered I would adjust the process. I like following the manual but that's just me.
    It is not that big of deal. Do what you like.
  21. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Surely it would have just been quicker to answer the original question Watson rather than take the pedant route?
  22. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I had overfilled mine on my first oil change. I used my vacuum brake bleeder and sucked out the excess out right through the fill port.
    Hope this helps
  23. WATSON
    23,933
    WI
    Geeez guys. I showed the guy how to search ferrarichat...which is a difficult thing to do within the provided search engine here. Type that in and a world of answers is at ytour finger tips....and not just checking oil levels.
    Did you know the "{topic} :ferraichat" syntax? I found it recently and it has been quite helpful.
    I'll refrain from helping going forward......sorry to have poked my head in here.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Waton, as I explained to you in our PM exchange, I assumed that you were "schooling" the OP to search and not ask questions that have been already asked many times - something that you did to me when I first became a member.
    If I assumed wrong, I apologize and as I said in PM, I had no intention to offend you.
    I'm on several forums and members seem to get very sensitive regarding topics already discussed, it does not bother me at all since new information often comes about and unless the search works well it's hard to get to the right place.
