Checking Oil Level on 355 | FerrariChat
Discussion in '348/355' started by enzob, Sep 22, 2007.
  1. enzob
    enzob Rookie
    Jan 31, 2004
    39
    San Diego, Ca
    Enzo Bertaggia
    In the owners manual it says to "stop the engine and check the oil level immediately". Is 10 minutes immediately enough? I checked the oil for the first time since buying the car. I put in 3 quarts and then started the car for about a minute and then shut it down. I then checked the oild and the oil was just starting to show on the dip stick, so I put in another quart. Should have I started the car and ran it longer before putting the last quart in?
    Thanks,
    Enzo
  2. F355Bvc
    F355Bvc Formula 3
    Dec 4, 2003
    1,725
    Lawrenceville. GA
    Vince Canipelli
    Get car up to operating temp(175 ), turn off engine, check. That's how I've always done it, or after a drive, cut off and check at once.
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    You can take the oil reading two ways.
    1) Just as it says in the book, immediately after engine shut off. And NO, 10 minutes is not immediately. Immediatly is with in seconds of shutting off the engine.
    2) How I like to do it, while the engine is idling.
    Checking the oil while the engine is idling is a quick way to see what you really have in the system. I check it with the engine idling first, then shut off the engine and run back and check it again. I get the same reading.
  4. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
    Careful not to overfill...
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yup. Adding 4 quarts blindly (or in this case, to a cold engine) probably means that you've got oil going up into your air filter area, clogging a MAF, etc.
    That's a good way to blow a head gasket or oil filter, too.
    What you want to do is to check your engine oil level when your motor is hot, such as after your left radiator fan has kicked on.
    Prior to your engine getting hot, your dipstick will act as though you are low on oil. The colder your engine, the less oil will be shown on the dipstick level mark.
    This is a pretty common "gotcha" for new Ferrari owners. It bit me. I got quite a puff of grey smoke for my first oil-checking effort. Time to drain a bit in your case, I suspect. Check that your air filter(s) isn't covered in oil, too.
  6. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Here's a question related to oil filling - just how important is it to have the right level as long as pressure reads ok? Or if it is below 'min' will pressure read low? Of course not recommending this as an alternative, just wondering....
  7. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    You can be low on oil and still have good pressure....
  8. UConn Husky
    Nov 11, 2006
    4,425
    CT
    Jay
    So bottom line it's technically 'ok' to be low on the dipstick as long as pressure is ok? Just wondering if there's reason to panic if the reading is low on the dipstick...
  9. 355Aussie
    355Aussie Formula Junior
    Jul 3, 2007
    688
    George
    Here is how I do it and never had any problem.
    Take the car for a good drive so it is at operating temperature.
    Whilst car is still idling take the dip stick out and wipe it.
    Then put it back in without screwing the cap and take it out again.
    If the oil is below the min level then add a little bit but not to much.
    If the level is over the min mark then there is enough oil in there.
    Don't be fooled trying to see oil at max level mark. It will not happen.
    Try this.
  10. The Don
    The Don Karting
    Oct 10, 2004
    131
    ''You can be low on oil and still have good pressure''
    So if your very low on oil, the oil pressure will not show it as low. So what is a oil pressure gague for? If thats the case then everycar is at risk of engine damage because there is no way of telling that you have low/high oil pressure. Overfilling you car can also effect the flow of oil and the pressure.
  11. renmure
    renmure Karting
    Dec 13, 2006
    86
    Scotland
    Jim
    That was helpful to me and I will do it that way in future.
    My biggest worry is trying not to end up with "Ferrari" scalded into my palm from the hot filler cap!! ;)
  12. pyroguy
    pyroguy Formula Junior
    Dec 20, 2006
    669
    Minnesota
    Steve
    Out of curiosity, does Ferrari recommend conventional or synthetic oil?
    Secondly, what are people actually using? Conventional or synthetic?
  13. CavalloRosso
    CavalloRosso Formula 3
    Jul 12, 2007
    1,423
    Atlanta, GA/Vail, CO
    SVO
    There ARE worst things!!!!
  14. The Don
    The Don Karting
    Oct 10, 2004
    131
    I am using Shell Helix Ultra 5w/40 for my 355 although the workshop manual states to use Agip 10w/40. Early 355's used the Agip but later 355's use the Helix.
  15. pyroguy
    Dec 20, 2006
    669
    Minnesota
    Steve
    Thanks Don. Getting ready to pull the trigger on a 96 355. Anyone else have any comments/suggestion/recommendations?
  16. Organiser
    Organiser Formula Junior
    Jan 13, 2004
    922
    West Midlands UK
    Phil Haynes
    Just get yourself a nice oven glove (Nomex Preferably), and keep it in the front luggage compartment.
    No more burnt hands!!
    Regards,
    Phil.
  17. f355spider
    f355spider F1 World Champ
    18,044
    Synthetic.
    And Synthetic.
    Although I prefer $7 per quart Mobil 1 versus $20 per quart Shell Ultra Helix.
