Checking wheel speed sensors on 599 | FerrariChat
Discussion in '612/599' started by Skidkid, Mar 18, 2022.
  1. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    So, what is the best way (proper way) to check/test wheel speed sensors for a 599? I suspect that one of my sensors is bad and is the root of the Christmas tree that is on my dash.
    I suddenly got manatino failure and CST failure warnings and the car went into slippery surface mode; I can't change modes. The shifting is really wonky, sometimes grabbing hard, sometimes slipping, and essentially never rev matching. There is one code that doesn't have a definition in the Leonardo. I didn't write the code down so I have forgotten. I will read it again and post the code later today.
    Of course I am open to other suggestions as well. The idea of wheel speed sensor suddenly popped into my head after thinking about this for a few days.
  2. Teejay
    Teejay Rookie
    Sep 12, 2017
    41
    Tim Jenner
    If it's the sensor you should also get an ABS warning.
  3. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Yes, I have that as well.
  4. Teejay
    Teejay Rookie
    Sep 12, 2017
    41
    Tim Jenner
    OK sounds like the sensor. Integral with the wheel bearing so a bit expensive plus two hours to fit.
    Skidkid likes this.
  5. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Good diagnostic scanners give one the ability to see what info is being reported to the ecm. One can see the actual wheel speed the ecm sees. Does your scanner do this?
  6. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    My scanner does not but my mechanic's does; I will have him isolate what wheel and do the work. If there was an easy way to find it, one I had the facilities to do, I would have done the diagnostic myself. I have a lift and pretty well stocked garage so I might have taken on the replacement as well. I am always game for a new project but without the correct scanner I will have him do the work. Unfortunately, he has been so backlogged I couldn't get in right away.
    Ianjoub likes this.
  7. DZ-96
    DZ-96 Formula 3
    1,908
    South Germany
    Daniel
    Sure that not a bad battery causes the faults.
    Sometimes strange things happens with bad batteries.
    Daniel
  8. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Already replaced. That is where I started.
  9. tazandjan
    39,195
    John- An SD3 should tell you what you need to know.
    Skidkid likes this.
  10. Skidkid
    Skidkid F1 Veteran
    9,547
    Campbell, CA
    John Zornes
    Thank you.
