CHICANE CUTTING ISSUE: FIA Asked By GPDA For Better Solution | FerrariChat
Discussion in 'F1' started by RP, Sep 24, 2008.
  1. RP
    RP F1 World Champ
    Feb 9, 2005
    17,667
    Bocahuahua, Florxico
    Tone Def
    (from autosport)
    The FIA has been asked by Formula One drivers to find a better solution to the problems caused by chicane cutting in the wake of the Lewis Hamilton Spa controversy.
    With Hamilton having lost his appeal over the penalty he was handed for gaining an advantage by cutting a chicane in the Belgian Grand Prix, there remains some unease about the expected driver etiquette in similar situations.
    Grand Prix Drivers' Association (GPDA) chairman Pedro de la Rosa thinks there has to be a better option to punish drivers for cutting chicanes, rather than the current guideline of handing back positions.
    "The bottom line is that there is the need to find a better solution that keeps everyone happy," he told autosport.com. "We have spoken with Charlie (Whiting) and the FIA, and they are looking for a solution as well."
    Chicane cutting has become a modern day issue because of the wide-open asphalt run off areas that now surround corners. Mistakes by drivers result in them simply running off the circuit without penalty and resuming further up the road.
    De la Rosa admits there is a difficulty in finding an answer as to how to design chicanes whereby they are both safe and do not encourage drivers to cut across them.
    "At the moment we have the best compromise," he said. "We all push for the asphalt run-offs, but one of the downsides of that is that you can cut corners without being penalised as much as with gravel or grass. So it's not all positive, but safety is first.
    "We have that because it's the safest measure, so the second step is to make sure that if a driver jumps a chicane he gets a proper time loss so there is no controversy. That is the main objective. But the GPDA perspective is just about safety.
    "I have nothing to say about jumping chicanes. We are happy with the run-off areas because we pushed for them, and now it is up to the FIA to find a solution to get proper time loss for a driver that jumps a chicane, not the GPDA."
    De la Rosa does not believe that the wider use of speed bumps to hinder drivers who cut across chicanes would improve matters.
    "It depends where you locate those. They should never be on the run-off areas, because it makes the car jump. But I am sure that there are other ways, or placing them in other areas. We are very happy with the asphalt, it is a massive step forward, but you cannot have all positives."
    For anyone that missed it, this is the complete transcript of the McLaren/Spa incident hearing in Paris last Monday:
    http://www.ferrarichat.com/forum/showthread.php?t=215128
  2. jk0001
    jk0001 F1 Veteran
    Oct 18, 2005
    6,706
    Sun Coast
    Jim
    Just use the same technology they use in parking garages. A spike strip. when they try to cut the chicane they get 4 flat tires, I don't see any advantage to cutting the chicane then.
  3. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    Build solid styrofoam (polystyrene? My dictionary tells me both are right) "walls" through the chicanes. Just so hard that you risk damaging parts of your car, like the front wing, but not hard enough to cause serious problems.
  4. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    Gravel fill all the chicanes like many of the large runoffs. Might be messy but it will slow the cars down substantially IF they even make it through.
  5. AustinMartin
    AustinMartin F1 Veteran
    Mar 1, 2008
    5,445
    Los Angeles/Idaho
    Now, THAT is innovative!
  6. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    Seems the best quick fix for now at least.
  7. SonomaRik
    SonomaRik F1 Veteran
    seems like the best approach: Instant penalty !!!!! no advantage
    However, a much needed solution is to have Permanent officials, where one ONE not most are from the host country. These officials would travel and be non-patisan.
    rik
