Chick Fil-a, Elvis and a red light. Two out of three ain't bad. | FerrariChat
Discussion in 'Mondial' started by srephwed, Jun 21, 2015.
  1. srephwed
    srephwed F1 Veteran
    7,093
    street,md
    fred brown
    #1 srephwed, Jun 21, 2015
    Had a wonderful 50's night at the local Chick Fil-a. If you haven't been to one make a point to stop in. They are fabulous. found out Elvis was my wife's cousin. Then on the way home it was getting dark and I noticed the red light in my oil pressure gauge was on. The needle was all but straight up and everything sounded fine. Now I mention that it was getting dark because I hardly ever drive at night in the deer infested roadways of MD in my beloved Ferrari and I can't see the light under normal driving unless I bend over to look. It seemed to come and go with no rime nor reason. Since the sender has only one wire I assume the gauge is what turns the red light on. Anyone ever seen this?
  2. srephwed
    srephwed F1 Veteran
    7,093
    street,md
    fred brown
    Sorry for the crapy picture. I forgot the camera.
  3. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    Have it checked before you end up with a hunka-hunka burnin' Ferrari V8
  4. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    Usually there are two senders, one for the gauge one for the light
  5. 308mon
    308mon Karting
    Oct 5, 2014
    169
    Check the oil pressure light switch sender and wire connection. The sender (smaller body) is on the opposite side (the side under the plenum) to the oil pressure sender (larger body) in the location of the base of the oil filter housing. Wire color code should be Gray/Yellow (Gray'Black for the oil pressure gauge sender wire).
  6. srephwed
    srephwed F1 Veteran
    7,093
    street,md
    fred brown
    24 dollar light switch from AW Italian and my problem is solved. Thanks!
  7. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    Wheeeew, that was a close one. I can sleep well tonight.
  8. JV's89
    JV's89 F1 Veteran
    7,298
    Pittsburgh, PA
    That's not very polite. ;)
  9. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #9 hank sound, Jun 27, 2015
    Howie, hear me now - - - -
    You mustn't be losing sleep every time you read about one of your Mondial brothers or sisters, experiencing some car related setback !! :):)
    If while looking for the right sized socket, we have to worry about your bloomin' sleep patterns, can you imagine just how fragmented our (already compromised) focus is? Being concerned as to whether you're tired or not, while I'm trying to deal with my initial car problem, makes me think more about you - than my car. I need to bill you. :):)
    Sleep well (no matter what),
    Hankster
  10. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    Fred please explain light switch ??? do you mean sending unit? or are you merely switching the light off so you dont see it??? lol
  11. srephwed
    srephwed F1 Veteran
    7,093
    street,md
    fred brown
    The little red light in the gauge is controlled by a different sender than the gauge
  12. 308mon
    308mon Karting
    Oct 5, 2014
    169
    Errr...???...that's what I said as per my previous post above:
    Check the oil pressure light switch sender and wire connection. The sender (smaller body) is on the opposite side (the side under the plenum) to the oil pressure sender (larger body) in the location of the base of the oil filter housing. Wire color code should be Gray/Yellow (Gray/Black for the oil pressure gauge sender wire).
