Chirping sound when releasing clutch | FerrariChat
Discussion in 'Boxers/TR/M' started by ozziindaus, Jul 5, 2013.
  1. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    I'm starting to hear what sounds like a chirping sound when I release the clutch. Anyone who hears it thinks I'm lighting up the tires which I'm obviously not. Doesn't happen all the time but I can almost predict when it will occur. Dealership said the clutch was good and I think so too since it holds pretty well without any signs of slippage. I'm thinking it's just me hesitating to fully release allowing it ride just before full engagement.
    Is this normal? Am I just a shi#y driver?
  2. chabch
    chabch Formula 3
    Aug 15, 2010
    1,075
    France
    Christophe
    If you are a sh$ty driver, then I'm one too. Same thing on mine, but only if I let the clutch slip a little more than usual, and I "know" when it's going to do it. I've seen video of TRs on YouTube doing the same sound. I'm also curious to know why since my clutch is also good according to Ferrari.
  3. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    After doing a bit of research, I think the possible causes of the noise just before full clutch engagement could be one of two things;
    -Clutch plate torsion spring vibration (harmless but I'm no expert).
    -Worn syncros (unlikely).
    I say the worn syncros are unlikely because you would probably hear that same noise all the time and definitely see slippage especially on high gears. I highly doubt I have worn ALL syncros out since I occasionally get the noise on all gears including reverse where there is no syncro.
    This is just my guess and the result of a few hours of YT vids.
  4. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Bad pilot bearing ????
  5. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,499
    romano schwabel
    could be
    could not be
    wrong: the reverse also has syncro
    the noise could be also from the drive plate. inside this drive plate covering there is some metal, this sometimes makes such noises when releasing the clutch. nothing serious.
    is this noise also when you start to push the clutch pedal or only when you release it?
    you may try to release the clutch faster to see if the noise will be gone
    what is when you have the gearbox in neutral and then push and release the clutch?
  6. khayes
    khayes Formula Junior
    Nov 1, 2003
    591
    Austin, TX
    Kelly Hayes
    As a 10 year owner of a Testarossa with the same clutch I have noticed the same sound too. The solution for me has been to release the clutch slowly at first and once it starts to grab I quickly release it the rest of the way. It only chirps when I do the slow release. The previous owner taught me to throttle up at the same time that I release the clutch (not before).
  7. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Really? Is this typical of Ferraris?
    Only on release
    This is why I say it is predictable. It only occurs when I hesitate (slow release). No sound in neutral or when I dump it.
  8. geno berns
    geno berns F1 Rookie
    Oct 26, 2006
    3,006
    Midwest
    Geno
    Is the noise coming from the tires chirping or inside the gear box?
  9. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Right on. I was fortunate enough to get a driving lesson from a Ferrari expert. He told me the same thing. My main take away was;
    -Alway blip the throttle during gear changes
    -Never force a gear in (use thumb or finger pressure only)
    -Never gear up below 2000 RPM
    -Keep it in neutral when coming to a stop
    -Keep it in neutral at a stop rather than using the clutch
    -Don't allow the wheels to drive the engine
    and most importantly, brakes are cheaper than clutches and gears so use them
  10. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    No way it's the tires but it sounds just like it.
  11. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    Mind didn't do it until I replaced the clutch several years ago. The clutch worked flawlessly but if I slipped it just a little it would "chirp"
    I asked around and was told it was normal. Considering how many others have the same condition, I'd say it is inherent of a dual disc clutch.
    I don't know if I got better at driving it but the sound went away with time.
    I found that driving it like a diesel was the best method. Stay off the throttle until you've almost completely released the clutch - then nail it! You're not going to light the tires up but you'll save your clutch, differential, etc. etc.
  12. chabch
    chabch Formula 3
    Aug 15, 2010
    1,075
    France
    Christophe
    +1
    That's how I do it too. I rarely get the chirp sound now.
  13. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,260
    Mel
    Opening up the clutch for inspection is not a very difficult job on our flat-twelves ...
    Could also be the clutch thrust beraring (dry) imo ...
  14. Testarossa Lover
    Testarossa Lover F1 Rookie
    Dec 31, 2006
    3,622
    Newport Beach, CA
    Haig Barsamian
    My was doing the same, it was bad T.O. bearing.
  15. Melvok
    Jul 25, 2008
    14,260
    Mel
    O.K. .... T.O. bearing ... :)
  16. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Possibly a Gryllidae
  17. turbo-joe
    Apr 6, 2008
    9,499
    romano schwabel
    what please is a T.O. bearing? former no. 126608, new number now 70000567 ??
  18. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    I believe so Joe
  19. turbo-joe
    Apr 6, 2008
    9,499
    romano schwabel
    but what says the T.O. ?
  20. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Throw Out bearing
  21. turbo-joe
    Apr 6, 2008
    9,499
    romano schwabel
    ah, ok ! ! ! thanks :)
